For plug wires I make one of four choices
1- OEM (new)
2- aftermarket - NGK
3- performance (with actual ignition upgrades and non-OEM Redline) - Magnecor
4- 2 sets of used OEM plug wires from junkyard ... Use one from the 2nd set if issues with the 1st.
The NGK's are at least as good as the OEM; often better in some way. As "Hot Rod" as necessary with an essentially stock motor.
Taylor, MOROSO, even ACCEL make a decent aftermarket ignition wire set; the problem being they are not better than the NGK nor as good as the Magnecor. If you want "the best" for road or off-road/track use, Magnecor is *the only* ignition wire to consider.
