I tried a bottle of the risilone engine treatment on my 03 f250 5.4 due to excessive start up clatter every time I start the truck. I tried several different brand oil filters thinking it was a drain back valve issue but the noise persisted regardless of the filter used. Within a few hundred miles of adding the risilone the noise is completely gone. My question is should I change the oil and filter or let the risilone in for the duration of the oil change. I usually use motorcraft 5w-20 and a motorcraft filter and change it roughly every 5000 miles. Thanks
