Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Need a tire
by Leo99
05/28/16 09:58 PM
Small Engine Oil Pressure
by funflyer
05/28/16 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
20 registered (Duffyjr, c502cid, bbhero, Duke, 2 invisible), 459 Guests and 102 Spiders online.
58001 Members
66 Forums
249545 Topics
#3418249 - 07/08/14 01:15 PM Using methonal to cut WMO?
sixtwoturbo Offline
Loc: Abbotsford, BC
I have access to probably 100 gallons of methonal, I currently use stale gas, mixed gas etc to cut but can't really find any info on using methonal to cut my brews. Anyone have a clue? TIA.
1984 G20 Get A Way van, 6.2 diesel with a remote mounted turbo-HX35 with a billet 60mm HX40 comp wheel, 20 psi, running waste fuels and jet fuel.
#3418265 - 07/08/14 01:24 PM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
Boomer Offline
Loc: Pennsylvania
When methanol mixes with the right amount of water, it will fall out of solution along with the water. It is why a lot of us used to use isopropanol Gas Dry. Does the methanol you propose to use contain any water? It is difficult to get it anhydrous and keep it that way. If it does have some water in it, you run the risk of it not mizing with the gas and settling out as a discrete layer at the bottom of the tank.
Also, on cold starts, methanaol has a propensity to form formaldehyde and formic acid as it partially oxidizes. It is not something I would want to run in a good engine...maybe a lawn mower???
2003 Saturn L 300 128,020 miles
2013 VW Passat TDI SE, 31,150 miles
2014 VW Jetta TDI SportWagen 16,870 miles
#3418329 - 07/08/14 02:06 PM Re: Using methonal to cut WMO? [Re: Boomer]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Also isn't methanol corrosive to some metals? From memory it is an issue when switching from gas to methanol in racing applications.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3418361 - 07/08/14 02:29 PM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
Rosetta Offline
Loc: Sta Catarina, Br
I'd prefer Ethanol, since methanol having a low BTu will make the mixture too lean and give a hard time for the ECU maybe throwing a CEL ...
Forget it, that a Diesel ...
Edited by Rosetta (07/08/14 02:31 PM)
1995 Ford Taurus 3.0 Vulcan 78k miles Mobil 1 5w30
1993 Subaru Impreza EJ16 121k miles Mobil 1 15w50
1997 Kawasaki Ninja ZX9R 38k miles Mobil 1 15w50
#3418422 - 07/08/14 03:20 PM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
Astro14 Offline
Loc: Virginia Beach
Wait, you're putting gasoline in your van's diesel fuel?
And now you want to cut the diesel fuel with methanol?
Do you hate this van? Are you hoping the engine will fail from preignition?
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#3421138 - 07/10/14 07:26 PM Re: Using methonal to cut WMO? [Re: Astro14]
sixtwoturbo Offline
Loc: Abbotsford, BC
Thanks guys, I'll stick with my gas and waste oils routine.
You really need to do some research on alternate fuels.
#3421368 - 07/10/14 11:03 PM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
Shannow Online   content
Loc: Oz
If you've got 100 gals of methanol, get yourself 500 gals of waste egetable oil, a few pounds of lye, and make biodiesel to add to your alternate fuels...
You will end up with a fair bit of glycerine to dispose of (or be creative), but it's a fun job (I only make it in half gal continers, use it as an additive (in engine oil, and fuel of gas/diesel cars)...not that often, only when I get enough dry alcohol.)...there's a couple players who partially esterify the oil, and have a partially thinned ester/glyceriene "fuel", which carries sodium/potassium from the lye...I wouldn't do that without an inline pump, and probably not then.
Or you could get on a biodiesel forum, and swap them the meth for some finished fuel...
#3421422 - 07/11/14 01:25 AM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
Loc: Oz
While talking same, been looking at stuff for a while on using E85 to make biodiesel.
Methanol is a pain to get in Oz, E85, marginally less so...would have (hopefully) unreacted petrol in the mix
#3422643 - 07/12/14 01:08 PM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
sixtwoturbo Offline
Loc: Abbotsford, BC
Thanks Shannow but way too much work, lol. I'll just let the guy keep it, he's adding it to his gas car.
Methanol in engine oil?
I also don't want to mix WVO and WMO, they can form some viscous sludge and weird build in the fuel system and internally in the engine.
#3422765 - 07/12/14 03:53 PM Re: Using methonal to cut WMO? [Re: sixtwoturbo]
Loc: Oz
I've used the biodiesel in engine oil as an additive, not the alcohols themselves.
Schaeffers have a similar product, and AutoRx is sort of a lanolin biodiesel if you study the patent.
