Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Replace oxygen sensor by mileage ?
by Merkava_4
07/01/16 10:02 PM
I was slightly wrong on the Purolator transition
by slacktide_bitog
07/01/16 09:57 PM
Things your dogs have eaten.....
by OVERKILL
07/01/16 09:45 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
30 registered (bobt2382, Blkstanger, bdcardinal, chrisri, 3 invisible), 861 Guests and 17 Spiders online.
58341 Members
66 Forums
251131 Topics
Page 2 of 2 < 1 2
#3329961 - 04/01/14 06:40 AM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Cujet Offline
Loc: Jupiter, Florida
Once again,
No common solvent dissolves hard carbon. Not Marvel Mystery Oil, not Berrymans, Not Carb Clean, not Seafoam, nothing.
Only chemicals that contain methylene chloride or other caustics will soften or dissolve hard carbon. Such as paint stripper, oven cleaner, paint gun cleaner and so on. Ever wonder why blocks and heads are cleaned with a "hot tank" caustic process? Placing them in a typical parts washer won't remove the carbon, regardless of how long you let them sit.
I have had success with higher viscosity synthetics in cars that consume too much oil.
Turbo's rule.
#3330449 - 04/01/14 03:11 PM Re: How do I clean the piston oil rings? [Re: Cujet]
Cleft_Asunder Offline
Loc: Reno, NV
Originally Posted By: Cujet
Once again,
Can I put any of those through the spark plug holes before an oil change and let it soak, or can I mess something up?
#3330516 - 04/01/14 04:05 PM Re: How do I clean the piston oil rings? [Re: Cujet]
friendly_jacek Offline
Loc: southeast US
Yes, but the ring groove deposits are not 100% hard carbon, at least not initially.
There are posts about rerings jobs in Saturns or Corollas after using solvents that showed clean but worn out rings.
Cleaning is doable, but has to be done before the rings are worn out or lose their tension.
#3330643 - 04/01/14 07:07 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Gokhan Offline
Loc: Los Angeles, California
Originally Posted By: Cleft_Asunder
I just replaced my valve seals and I am still consuming lots of oil.
Are you sure that it was done right? It's not difficult to damage or break these very delicate seals during installation. Also, if they aren't seated properly, they will pop out and then you have no seals.
I had posted this a while ago:
Wonders of valve-stem oil seal replacement
I'm confident I did it right, just the way you described in your DIY, but I will check again soon, just to make sure they haven't come loose. Thanks.
Did you hear the "click" seating sound for all of them when you pushed them down?
1985 Toyota Corolla LE, 4A-LC engine, ~ 264,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3331406 - 04/02/14 01:22 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Cujet Offline
Once again,
I think what you are asking is if you can use very harsh, often caustic chemicals internally in your engine. Absolutely not! While the piston, valves and rings won't likely be affected by them, seals, gaskets, plastics, composites and rubber parts will be destroyed by them. Yes, I've used EZ-OFF engine cleaner to clean intake manifold ports and intake valves. But, only with the valve closed, done carefully-one at a time, and the metal intake manifold sitting in the driveway smile
Today, I'd never do such a thing. I prefer to use synthetic oil to prevent or reduce the risk of carbon buildup on rings and valves. My suggestion stands: Try a higher viscosity, quality synthetic oil. Possibly high mileage Mobil 1, 10W-40. It's use will help clean and keep clean engine internals.
Turbo's rule.
#3333535 - 04/04/14 06:46 PM Re: How do I clean the piston oil rings? [Re: Cujet]
Loc: Reno, NV
Once again,
Why such a high viscosity? Because it is less likely to seep through the rings? I was thinking about increasing my viscosity to 5w-40 at first, but your suggestion sounds better since I would burn less oil in the winter too. I think I will continue using valvoline high mileage synthetic blend, plus adding some LC20 in there.
Edited by Cleft_Asunder (04/04/14 06:48 PM)
#3333539 - 04/04/14 06:51 PM Re: How do I clean the piston oil rings? [Re: Gokhan]
Loc: Reno, NV
Yes I did hear it each time. The valve job is a PITA with that OEM tool we both used. I would never recommend anyone use it, and to instead find a tool that actually compresses the spring without it wanting to fly out in my face, which it did.
Page 2 of 2 < 1 2
