looking for a good garden hose reel
by bowlofturtle
05/02/16 02:03 PM
New WD Blue 2.5" hard drive beeps???
by Drew99GT
05/02/16 12:39 PM
Grease for Craftsman Snow Thrower
by GGorman04
05/02/16 11:19 AM
Napa syn $2.99 qt.
by pda1122
05/02/16 10:59 AM
Can you mix brands of DOT 4 brake fluid?
by enochian
05/02/16 10:50 AM
rust on stainless steel pool rail and ladder
by raaizin
05/02/16 10:50 AM
Anybody have experience with Lubrication Engineer
by gmh101357
05/02/16 10:43 AM
Oil for a ford 302
by mazdamonky
05/02/16 10:37 AM
93 mercury sable unlock steering wheel
by cptbarkey
05/02/16 10:24 AM
Ford F250-350 Interstate MPG with the 6.2L Gasser
by AirgunSavant
05/02/16 10:12 AM
What do you class as good oil pressure?
by MARTNT
05/02/16 09:53 AM
A bit of tractor maintenance
by Pop_Rivit
05/02/16 09:44 AM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
94 registered (137_Trenton, Alfred_B, 87sammy, asand1, 13 invisible), 1984 Guests and 322 Spiders online.
57767 Members
66 Forums
248368 Topics
Page 3 of 7 < 1 2 3 4 5 6 7 >
#3295223 - 02/26/14 03:01 PM Re: Son of Dexos coming 2015 [Re: Solarent]
TiredTrucker Offline
Loc: Central Iowa
My 2013 Silverado, the manual states dexos1 or equivalent. So I generally don't waste any time or sleep worrying about if a motor oil is on the "approved" list. The one I use claims to meet the spec, though it is not on the list. And that is fine with me. As to whether it is right, wrong, or somewhere in between for GM to get a royalty fee out of an oil that is on the "approved" list really doesn't mean much. Heck, Mobil has to pay a royalty to NASCAR to have that "official oil" branding on it's products. No different with some other product being the "official" product of whatever organization.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#3295341 - 02/26/14 04:49 PM Re: Son of Dexos coming 2015 [Re: Solarent]
Trav Offline
Loc: MA, Mittelfranken.de
Just one of the things unique to Dexos spec.
Quote:
The GM dexos oil has one spec that ILSAC and API labeled oils do not have. This is quite important! That dexos requirement is for better resistance to aeration, which is the whipping of air bubbles into the oil. Engines with variable valvetrain (variable camshaft timing) technology use engine oil as a hydraulic fluid to move components in the engine, i.e., hydraulic lifters.
If air bubbles are in the oil, the lifters will not act as fast as the engine controllers expect. On the mild end, this can limit engine performance and economy. On the extreme end, this slow response can throw a MIL or DTC check engine code. Chevy, Dodge and Ford police vehicles all use engines with a variable valvetrain timing!
For all practical purposes, put Mobil 1 in all GM police vehicles. The use of synthetic oil has always been a good match for how we use our vehicles. Now, according to GM, it is a requirement.
http://www.hendonpub.com/police_fleet_manager/articles/2012/1112/dexos1_motor_oil_required
Quote:
Key differences between dexos1 and ILSAC GF-5/API SN are:
GM Proprietary Test: Opel RNT and Opel OP-1
Includes ACEA Engine Tests: TU5JP, TU3MS and M271SL
Higher Seq. IIIG Weighted Piston Demerit requirement: 4.5 vs. 4.0
Higher Seq. VG sludge requirements: AES 8.3 vs 8.0, RCS 8.5 vs 8.3
Lower Noack Volatility: 13% vs 15%
Better Shear Stability: Requires passing the Bosch Injector
Shear Stability Test
http://www.mfaoil.com/images/E0138901/dexos.pdf
And Dexos vs GF-5
http://www.pceo.com/101510_EO_PV1202_AR.pdf
#3295365 - 02/26/14 05:10 PM Re: Son of Dexos coming 2015 [Re: demarpaint]
strat81 Offline
Loc: Nebraska
Originally Posted By: strat81
However, if I'm mistaken, I'd bet there are many others that are too. "I can put any Dexos oil in my Vette or CTS-V and run hot laps with no problem."
If that's what your Vette or CTS-V calls for and GM warranties the engine, what's the problem? I'd be more concerned using an oil they don't approve and running hot laps. JMO
Under warranty, a blown engine is an inconvenience.
Out of warranty, a blown engine can cost big $$$$.
Molon Labe
#3295367 - 02/26/14 05:12 PM Re: Son of Dexos coming 2015 [Re: Trav]
strat81 Offline
Loc: Nebraska
It makes me uneasy that the same oil that's spec'd for puttering around at 50mph is also spec'd worldwide and may be used in sustained high speed driving in Germany or for track use anywhere.
Things change. Todays oils are not the same as they were even 10 years ago, lot of Opels and Fords run on the Autobahn every day for years on 5w30 without any lubrication problem.
If its good enough for an LS7 or LS9 its good enough for an Opel 1.4 or 2.0 regardless of how high it revs.
A few years ago i would agree with you 100% but like i said things change. Todays commercially available retail oils have never been better.
I believe GM when they say the Dexos spec is that good, after all its them that will have to foot the bill if it isn't.
You (and GM) may be right.
But compared to other high-end specs like BMW LL-01 and Honda HTO-06, Dexos seems weak.
*shrug*
Molon Labe
#3295385 - 02/26/14 05:35 PM Re: Son of Dexos coming 2015 [Re: strat81]
Trav Offline
Many Dexos approved oils also meet other specs like HTO-6.
Some German/Euro cars like BMW and MB use oils with a higher min HTHS. Its not better or worse it depends on how the engine was built.
GM has had great success globally with 5w30, they build the engines to run on that viscosity.
That is not to say they wont run well on alternative viscosities which may be spec for different climates eg extreme hot or extreme cold climates or due to availability.
Quote:
Mobil 1 5W-30 synthetic motor oil meets or exceeds the requirements of:
ACEA A1/B1, A5/B5
API SN, SM, SL, SJ
ILSAC GF-5
Ford WSS-M2C946-A
Ford WSS-M2C929-A
Mobil 1 5W-30 has the following builder approvals:
General Motors Service Fill dexos1 dexos1 logo
Honda / Acura HTO-06
Mobil 1 5W-30 is recommended by ExxonMobil for use in applications requiring:
General Motors 4718M
General Motors 6094M
#3295476 - 02/26/14 07:18 PM Re: Son of Dexos coming 2015 [Re: Trav]
fdcg27 Offline
Loc: OH
Require an oil with a transparent standard?
Sure.
Require an oil with an opaque standard and a logo the blender has to pay for?
Cash grab, pure and simple.
Nothing wrong with GM setting an oil spec.
Everything wrong with GM not publishing the spec and charging a royalty on every quart for the lame logo.
Mercedes doesn't do this, VAG doesn't do this and BMW doesn't do this.
Why should lowly GM?
I'm quite sure that any oil carrying the Dexos logo is a good oil.
The thing is, many others are as well and without some recognized spec, like A3/B4, buyers are left in the dark as to what is really required.
Pay GM or you can't have an oil meeting the spec?
Ludicrous!
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3295504 - 02/26/14 07:42 PM Re: Son of Dexos coming 2015 [Re: Solarent]
buster Offline
Loc: NJ
This is really a good thing overall, I think. We're getting to the point where brand no longer matters because the specs are now so demanding and synthetics are becoming so common that all the companies are now offering "top tier" oils. And they all perform very similarly. It's mostly all marketing.
10 years ago or so, it was Mobil 1 or a very average synthetic and below average regular API conventional oils. So the gap has closed significantly.. All of the companies are fighting to differentiate their products with 50 tiers. It's becoming riiiiidiculous. But that's how it works.
Consumers will often go with what is the least expensive. If I'm an automotive company and concerned about the reliability of the engines we produce, I'd rather see the bar raised. Especially considering the pressure coming from regulators with CAFE etc.
#3295514 - 02/26/14 07:51 PM Re: Son of Dexos coming 2015 [Re: Trav]
FutureDoc Offline
Loc: North Carolina
Which is?
OK, we are kinda getting some information, but not much. Still a really murky area. Volatility is the only metric that is commonly available. ILSAC Gl-5 varies from 7.5 to 8.9. The piston varnish would be 7.5 but average engine would be 8.0 for sludge 8.9 for varnish, rockers are 8.3. More data please
See, numbers are useful. If we had the full breakdown of Dexos, then we could compare ILSAC/API against Dexos... rather than depend on non-scale graphs.
On a side note,is it just me or did the older 4718M seem to have a higher "tier" of oil choices than Dexos. Sure API and ILSAC standards have jumped and conventionals have gotten better but it seemed like 4718M was more exclusive
Edited by FutureDoc (02/26/14 07:55 PM)
'01 MR2 Spyder,59K, Havoline Syn 5w30
'99 Subaru Legacy Outback, 212K, T5-Wix
'14 Subaru Outback, Havoline 0w-20 & Wix
Fleet Manager, Ph.D.
#3295584 - 02/26/14 09:08 PM Re: Son of Dexos coming 2015 [Re: fdcg27]
TrevorS Offline
Loc: California
Sure.
Ludicrous!
Agree
And I wonder if in a roundabout way it violates that Moss Magnussen Act?
After all you are required to buy an oil that profits the car manufacturer.
#3295595 - 02/26/14 09:23 PM Re: Son of Dexos coming 2015 [Re: TrevorS]
FutureDoc Offline
Loc: North Carolina
Sure.
Ludicrous!
Agree
Agree overall
They get around it by allowing other oil companies to license their product. So they are not forcing the consumer to by a specific brand or their brand. To them, the are offering the consumer a "choice" and that kinda gets around it. Still not in the spirit of the law IMO.
However, it is their burden proof to say you did not meet their specs. So, there is that loophole that as long as you use an oil that meets the specs of Dexos, then it is fine (even if it is not Dexos licensed) however, because they keep that spec secret, then it makes it a big murky mess that the consumer might not easily be able to know beforehand.
For example, "Supertech Syn" (our favorite non-Dexos debate brand) could potentially meet Dexos standards (It's NOACK is meets the Dexos standard btw) but without knowing those "proprietary" tests GM uses, we dont know for certain. So, logically, we can neither confirm nor deny that any non-dexos labeled oil meets Dexos spec. Because it is a license and has that "payment" attached to it, no-one knows if the non-labeled oils are less than spec or that the blender/oil just did not pay the fee.
Shame that GM "bought back" the government's stake because it would have been interesting to use FOIA to dig out the Dexos standards (but I doubt that would fly anyway)
#3295729 - 02/26/14 11:41 PM Re: Son of Dexos coming 2015 [Re: FutureDoc]
Nate1979 Online   content
Loc: Portland, OR
I have never heard such ridiculous arguments. Are you telling me that if GM published the Dexos spec that Walmart has published enough performance info on their Supertech oils to allow you to judge if it meets the spec or not? You have got to be kidding. Please post a single example of an oil company that has published all of their performance specs for a single oil showing they meet a spec. Any single spec. I have never seen this level of details published on BITOG ever. The people who actually need to know the spec (the blenders) know full well the details of Dexos.
Sure.
Ludicrous!
Agree
Agree overall
2015 GMC Sierra 2500 6.0L Factory fill
2010 Subaru Forester 2.5X QSUD 5w-30 w/ Fram Ultra
#3295798 - 02/27/14 04:48 AM Re: Son of Dexos coming 2015 [Re: FutureDoc]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I have been outspoken about Dexos... as it only helps GM bottom line and not the consumer.
I mentioned many months ago, on this topic, to not underestimate the power of the bean counters. GM isn't looking to get rich off of dexos1 royalties. Nonetheless, I can certainly see one or more bean counters insisting that a new, all encompassing specification that includes advertising and labels be self-funding.
And I don't begrudge them, completely, for not publishing everything about dexos1 requirements for free and in the open. We all know that "meets and exceeds" can be a reasonable alternative. Meeting and exceeding is a lot easier when someone gives the criteria away.
GM isn't an open source company. They're not in business to give intellectual property away for free.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3295801 - 02/27/14 05:09 AM Re: Son of Dexos coming 2015 [Re: Garak]
SteveSRT8 Offline
Loc: Sunny Florida
Good point, and very astute. The bean counters run car companies, the bigger ones even more so...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3295812 - 02/27/14 05:45 AM Re: Son of Dexos coming 2015 [Re: Solarent]
demarpaint Offline
Loc: NY
I'm just curious, how does this compare to Mobil not meeting the MS6395 Chrysler spec? There's lots of talk about GM grabbing cash, management, the bean counters, etc. in this thread, it got me thinking about Chrysler and Mobil. Is it just sour grapes/politics, or is Mobil not up to the task in Chrysler applications? Dangling the warranty carrot in front of the nose of any new car owner is always something on many of our minds. Thanks.
God Bless Our Troops
#3295814 - 02/27/14 06:00 AM Re: Son of Dexos coming 2015 [Re: Garak]
fpracha Offline
Loc: MA
GM isn't looking to get rich off of dexos1 royalties. GM isn't an open source company. They're not in business to give intellectual property away for free.
+1. its true and why should any intellectual property be given away for free anyways...
