PL10241 Cut Open
by Vegoose
02/11/16 11:15 PM
Seems like common sense to me......
by Doog
02/11/16 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
02/11/16 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
02/11/16 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
02/11/16 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
02/11/16 08:56 PM
Paint correction
by mjoekingz28
02/11/16 08:55 PM
Filtertran Filter From My Vehicle 96K Miles
by oil_abuser
02/11/16 08:53 PM
Bleeding brakes cleanly
by mjoekingz28
02/11/16 08:51 PM
Any thoughts on the Super Bumper? (Hitch Bumper)
by Fsharp
02/11/16 08:37 PM
Ransomware.....
by BrianF
02/11/16 08:22 PM
Electic motor lube oil
by Ztill
02/11/16 07:39 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
70 registered (bbhero, BTLew81, bdcardinal, 01rangerxl, akela, Bandito440, 3 invisible), 881 Guests and 214 Spiders online.
56899 Members
66 Forums
244576 Topics
#3200960 - 11/29/13 02:46 AM Best oil for a 09 Subaru Legacy Diesel
Khaled4WD Offline
Loc: Algiers - Algeria
Hi everyone.
I recently removed the DPF and the catalytic converter from my car, so I can use a high ZDDP oil now or a good mixture. Here's some of what is available here :
- Castrol
- Liquimoly
- Mobil1 (not sure)
- Total
- BP
Any recommendations ?
#3200972 - 11/29/13 05:10 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: Khaled4WD]
NHGUY Offline
Loc: USA
A flat 4 diesel? Hope they can keep head gaskets better than the gas flat 4s here.
#3200978 - 11/29/13 05:42 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: NHGUY]
Khaled4WD Offline
130.000Km now, so far so good.
2009 Subaru Legacy Diesel
#3201064 - 11/29/13 08:52 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: NHGUY]
LoneRanger Offline
Loc: Midwest
HG's haven't been an issue on the Subaru boxer 4's since about 2008.
'09 Subaru Forester .......... (Quaker State Syn Blend 5W30)
'13 Ducati Multistrada 1200 (Spectro Platinum 15W50)
#3201068 - 11/29/13 08:57 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: Khaled4WD]
LoneRanger Offline
Loc: Midwest
Liqui Moly would be my first choice out of that group of oils, Castrol my second choice. Both do well in the Pumpe Duese version (up to model yr 2006) of Volkswagen's TDI (diesel) which needed a very strong oil due to the high loading on the cam which drives the unit injectors per cylinder. You don't mention Pentosin, but if it is available in your region it would be an equivalent choice to the Liqui Moly.
Originally Posted By: Khaled4WD
Hi everyone.
- Castrol
- Liquimoly
- Mobil1 (not sure)
- Total
- BP
#3203287 - 12/01/13 08:00 PM Re: Best oil for a 09 Subaru Legacy Diesel [Re: LoneRanger]
bigjl Offline
Loc: London, England
They were not a problem in the UK/Europe except in the usual suspects of cars which were neglected.
Is the difference that UK models are Made in Japan and US models are made in the USA?
The flat four diesel is a nice smooth engine. A bit lacking in low end grunt but a nice smooth engine once they fixed the initial running issues, flat spots i believe was the most significant from memory.
Must admit i would be looking at Mobil 1 NewLife 0w40.
10 BMW 116D SE 110k miles Full BMW Hx
12 Jaguar XJL 3.0 D Luxury 132k 5w30 Shell AF-L
#3205157 - 12/03/13 03:53 PM Re: Best oil for a 09 Subaru Legacy Diesel [Re: Khaled4WD]
KenO Offline
Loc: Auburn, GA
God I wish I could get a diesel Subaru here in the US.
1995 Volvo 960 ShagginWagon
1995 BMW 328ti
1997 Chevy C2500 5.7l V8
1998 BMW 528i
#3205287 - 12/03/13 05:47 PM Re: Best oil for a 09 Subaru Legacy Diesel [Re: Khaled4WD]
bigjl Offline
Couldn't you import one yourself from say Germany or Belgium?
#3206320 - 12/04/13 04:34 PM Re: Best oil for a 09 Subaru Legacy Diesel [Re: bigjl]
artificialist Offline
Loc: Florida
The process is so expensive, that it doesn't make sense to do that with a common family car.
The only cars found outside the USA that get imported regularly are R34 GT-Rs and Porsche 959s, AFAIK.
2010 Lancer Ralliart Sportback
#3237252 - 01/04/14 02:13 PM Re: Best oil for a 09 Subaru Legacy Diesel [Re: NHGUY]
Khaled4WD Offline
Recently I had a major engine failure : broken crankshaft + cracked engine block...
#3237567 - 01/04/14 07:33 PM Re: Best oil for a 09 Subaru Legacy Diesel [Re: bigjl]
fdcg27 Offline
Loc: OH
The 2.5 may not have HG issues after 2008.
I hope not, since we have a 2009.
The HG failures had nothing to do with maintenance and everything to do with an engine design stetched to its limits.
Country of manufacture is not an issue, since the Legacy line cars were and are built at a plant in Indiana while the Impreza based cars are built in Japan.
Our Forester, for example, was built in the land of the rising sun.
I recently bought a '99 Legacy L AWD wagon for cheap, but only because the owner was a Subaru guy (he has seven others, including an STI and a WRX) and only because it had the 2.2.
I suspect that the OP is only teasing us in America, since the diesel Subaru is as available to us as is the diesel Accord.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3237898 - 01/05/14 02:13 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: KenO]
Khaled4WD Offline
You can get a Subaru Diesel engine in the US from here : http://boxeer.com/
#3605139 - 01/19/15 09:15 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: Khaled4WD]
Khaled4WD Offline
I'm going to rebuild my boxer diesel engine in the next couple of weeks (new engine block, crankshaft, main bearing, piston rings)
What oil should I use for break in period ? there isn't much of a choice here :
Castrol (10w60 ?)
Liqui-Moly
BP
Total
What about using motorbike oil like Castrol Power Racing 10w40 ?
#3656854 - 03/07/15 08:03 AM Re: Best oil for a 09 Subaru Legacy Diesel [Re: Khaled4WD]
Khaled4WD Offline
Some mail exchange with liqui-molly about their Synthoil oils :
Dear Khaled *******
Thank you for your inquiry and your interest in Liqui Moly products.
The ZDDP content of our Synthoil oils is 900 - 1100 ppm.
Due to environmental provisions can the ZDDP content not be higher.
-HTHS number:
Synthoil Energy 0W-40, Synthoil Longtime 0W-30, Synthoil High Tech 5W-40 and Synthoil Race Tech GT1 10W-60 = > 3.5 mPa.s
Synthoil Longtime Plus 0W-30 = > 2,9 < 3,5 mPa.s
Should you have any further questions, please contact us.
Best regards
i. A. Roman Göser
Anwendungstechniker
Hello Mr Goeser and thanks to you.
- Are the Synthoil lubricants group 4 or group 5 oils ?
- Do you have offroad or racing oils with higher ZDDP levels intended to be used where no environmental regulations are applied ?
Regards.
Khaled *******
Dear Khaled *******
Our Synthoil Lubricants are all group 4 oils on PAO base.
We don´t have any oil with a higher ZDDP content. For a better wear protection we use special EP-additives (Extrem Pressure).
Because this additives are better for the exhaust system (catalyst converter) and for the environment.
Best regards
i. A. Roman Göser
Anwendungstechniker
