Try hotshots stiction remover.Hi everyone, recently bought another MB diesel, a 97 W202 C250 Turbodiesel this time, with the OM605 turbocharged engine. It has 370k km (about 230k miles).
It has quite a bit of blow-by, the cap isn't really dancing but it looks and sounds like it would fill up a plastic bag in no time. I don't know much about how the car was serviced. All i can say is that even with an almost dead battery, it starts beautifuly at the first crank rotation when cold and it pulls quite hard for what it is. Maybe the provious owner ran it on crap fuel and not enough oil changes and mostly did short distances.
Perhaps the rings are coked and i could slowly improve things with a bit of TLC. What oil would you use? I'm not talking about specific brands as i live in europe but mostly specs. All PCMO are A3/B4 rated but i also have access to a good selection of HDEO as i have a tractor supply store nearby. Which HDEO specs should i look for?
Group I has become relegated to use in additive packs to keep them in suspension before blenders blend up a final lubricant/product. I'm not confident that there are many automotive lubricants that contain bulk Group I--everything's been appreciably replaced with Group II in North America. @Foxtrot08...I use a group one SAE 40 such as Delo 400 or Duron to clean up old engines....
That’s called “making a submission to a higher authority as a negotiation tactic”.Group I has become relegated to use in additive packs to keep them in suspension before blenders blend up a final lubricant/product. I'm not confident that there are many automotive lubricants that contain bulk Group I--everything's been appreciably replaced with Group II in North America. @Foxtrot08
Not really. Facts aren't negotiated, and he is a great source of truth for the forum. He's not a 'pal.' If I'm wrong, he's willing to squash my statement. And that's a reply helpful to me and this thread..
"Today, in the US, Group I base oils have been displaced by Group II oils"How Do Viscosity Index Improvers Work?
Originally Posted By: kschachn Originally Posted By: Red91 The Chevron Oronite link puts it in basic, understandable terms. If I'm interpreting correctly, the VII allows more flow at lower temperatures because it shrinks the oil's molecules, no? No. Nothing is happening with the oil. The oil...bobistheoilguy.com
Also, he has mentioned the cost of group I has gotten very expensive. Since Group I doesn't help blenders meet modern specs, it is rational to see that blenders aren't going to find financial leverage to use it.
Group I blends work for deposit solvency, just not confident anyone can find it on the shelf. Is there info to provide confidence on the contrary?
Without doing a leak down test how do you know what the blow-by is?I am going to remove the CCV next week while everything is apart (valve cover & intake plenum gaskets). Did an oil change two days ago, flushed the engine for 15 min with a liter of diesel, put 7 liters of fresh 15W40 in and a new filter and there's less blow-by now. Still some but 100% sure that either the flush or the 15W40 did something.
Just the old cap dance test. I know, it's just observation and i don't have numbers to back it up.Without doing a leak down test how do you know what the blow-by is?
