Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
23 registered (Black_Thunder, car51, CLOVER, brslds, 3 invisible), 855 Guests and 10 Spiders online.
58632 Members
66 Forums
252385 Topics
Page 1 of 2 1 2 >
#3073984 - 07/23/13 01:18 PM Changing ATF.
Viscosity Offline
Loc: Tx
I have a 2000 suburban. I have never changed the AT fluid. I have heard over the years that if you wait too long to change it you may as well not change it as when you do, the new fluid will cause problems with the seals. I have no idea whether there is any truth to it or not. Maybe some of you gurus can tell me whether or not there is any merit to this claim.
BTW, I am currently at 170K and having no issues with my transmission.
Edited by Viscosity (07/23/13 01:18 PM)
#3073988 - 07/23/13 01:24 PM Re: Changing ATF. [Re: Viscosity]
randomhero439 Offline
Loc: ohio
New fluid will clean all the sludge and varnish out of the transmission. It is very important to change the transmission filter during this process. Lots of high mileage transmissions fail after a fluid change, cause the filter was not changed. The cleaning action clogs the filter and starves the transmission for proper lubrication.
I would change it. But change the filter after you change the fluid.
'00 S2000: Amsoil 10w-40, Honda OEM PCX, 129k
'03 Accord V6-6MT: Edge 5w-20, Honda OEM, 243k
'10 Mercedes GLK: M1 0w-40, Mann, 63k
#3073991 - 07/23/13 01:26 PM Re: Changing ATF. [Re: randomhero439]
Viscosity Offline
Loc: Tx
Are you saying to change the fluid, let it run for a few days, and then change the filter or just do it all at once.
I had planned to change the filter.
#3073995 - 07/23/13 01:30 PM Re: Changing ATF. [Re: Viscosity]
Loc: ohio
Yeah pretty much what im saying. You could change the filter twice if you'd like, once when you start, then again maybe a week or two later.
IDK how hard it is to change trans fluid on your truck, whatever is feasible for your wallet and time.
Have you done the diff fluid in the truck yet?
#3074012 - 07/23/13 01:48 PM Re: Changing ATF. [Re: Viscosity]
PhillyJoe Offline
Loc: PA
I would drop & clean the pan, change the filter and refill with Dex VI. Since you are only changing about half the fluid this way, I would do it again in 6 months.
#3074023 - 07/23/13 01:59 PM Re: Changing ATF. [Re: PhillyJoe]
Donald Offline
Loc: Upstate NY
This plus installing a $20 Magnefine inline filter to catch all the loosened crud hopefully before it circulates too much.
One thing thing to remember is no flush or chemical can do a good job cleaning the filter. It needs to be replaced. Some like to say they can flush the ATF and by adding a chemical it will clean the filter too.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3074025 - 07/23/13 02:00 PM Re: Changing ATF. [Re: randomhero439]
NightRiderQ45 Offline
Loc: Houston, TX
Baloney!!! This is not true at all. Most modern cars don't have a filter, it's a metal mesh screen that's called a filter.
2002 Lexus GS300
1998 FGY33 Infiniti Q45 257k....RIP
#3074041 - 07/23/13 02:25 PM Re: Changing ATF. [Re: Viscosity]
wirelessF Offline
Loc: Oahu, Hawaii
In the 4L60E I would recommend changing the filter since its a paper felt type. Since the pan has to be removed to change the fluid (some don't have drain plugs) might as well change the filter and clean out the pan.
#3074057 - 07/23/13 02:38 PM Re: Changing ATF. [Re: Viscosity]
supton Offline
Loc: NH
Be thankful you have a dipstick! "Modern" transmissions lack this basic feature. *grumble*
2011 Toyota Camry, base, 6spd manual, 117k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 127k, his
#3074070 - 07/23/13 02:45 PM Re: Changing ATF. [Re: Viscosity]
Kuato Offline
Loc: In transit...
Fresh fluid should help preserve your transmission for longer, and a pan drop and refill now, then again in 5-10k miles, then repeat every 30k after that should see you through.
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#3074146 - 07/23/13 03:59 PM Re: Changing ATF. [Re: randomhero439]
Viscosity Offline
Loc: Tx
Nope. I need to do that as well.
#3074236 - 07/23/13 05:30 PM Re: Changing ATF. [Re: Viscosity]
901Memphis Offline
Loc: Northern Kentucky
How does the color look on the dipstick if you blot it on a white towel? Just curious. I recommend Supertech dex 6 at Walmart it's less than $4.50 a quart and pretty good stuff.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3074245 - 07/23/13 05:39 PM Re: Changing ATF. [Re: NightRiderQ45]
RF Overlord Offline
Loc: Cape Cod, MA
You can't make a blanket statement like that. Ford RWD vehicles with the 4R70W have a regular "media" filter. So does my sister's '08 RAV4...
How come no one ever advises installing a drain plug on transmissions that don't have one? I install them on every car I own and it makes doing regular drain & fills a lot quicker and a LOT less messy.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
#3074308 - 07/23/13 06:29 PM Re: Changing ATF. [Re: Viscosity]
tommygunn Offline
Loc: usa
@RF, I always advise to install a drain plug, especially if there is an aftermarket pan with one available.
@OP and everyone else, I guess:
I thought these trucks had a drain plug.
If so, then you don't need to drop the pain. Just drain thru the drain plug.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#3074488 - 07/23/13 10:34 PM Re: Changing ATF. [Re: 901Memphis]
Viscosity Offline
Loc: Tx
I checked it with a white rag and it's reddish in color.
Additionally, there appears to be a drain plug on mine. However, I'm planning on changing the filter so the pan is coming off. Any advice on putting the pan back on. Should I put it back on dry or use a sealant?
Page 1 of 2 1 2 >
