As much as those torque wrenches are uncomfortable and just plain unpleasant to work with, they hold their calibration quite well. If you've had it checked (and you should always have any torque wrench checked before the first use) once you can reasonably expect it to hold it's calibration for many years.
If that's got the valve covers I'm thinking of the old gaskets were baked in there but good weren't they? As I recall it can be a good two hours or so with the covers off just to remove all of the old gasket material. Maybe some got stuck in there or perhaps you bent the cover a little while digging the gasket out?
Either way, that torque spec is for clean dry bolts going into clean dry holes. If they're a little oily you're going to have a problem. I'd ignore the spec and tighten them very snug with a palm ratchet, let the engine warm up, then re-tighten them to very snug still with a palm ratchet. Add maybe 30 degrees beyond that but not too much more.
