quick note:
Unless your engine is eating too much oil ( .5qt / 1500 -2000 miles) dont use high milage.
The high milage stuff swells up the seals and if you keep switcing back n forth could cause damage , I dont think high quality like mobil1 will do that, but better be safe than sorry.
As long as you change your oil and filter everytime during timely manner , it doesnt matter too much what you use.
Do a blackstone kit with your next oil change and keep it simple , if there is no issue , no need to buy expensive stuff
http://www.blackstone-labs.com/
^ get castrol gtx and purolator or fram and test. dont use any fuel injector cleaner because it can give faulse readings.
i hear alot of negative comments with FRAM filters, personaly never had problem but i stay away because last thing i need is blown oil filter in middle of freeway
