Originally Posted By: Tegger
Originally Posted By: johnsmellsalot
I don't see an ABS unit under the hood. There are no abs lights that come on when I put the key in the on position. I just bought the car. It's a 2008 Chrysler PT Cruiser. Also, how would I know if it has traction control?
This thing evidently didn't come with an Owner's Manual...
Things like ABS and traction control are indicated by lamps ("idiot lights") within the instrument panel. These will illuminate for a short period of time when the ignition key is first turned to "run" (the last setting before "start"). If you do not see either light, then you probably don't have either feature.
Shine a flashlight on the instrument panel so that you can see any lettering or images that might be behind the visible fascia. If somebody has removed bulbs to hide faults and is claiming that the vehicle lacks the features you're hoping for, the flashlight trick will flush that out.
To confirm the presence/absence of ABS, turn the road wheels all the way to one side (doesn't matter which one, you're just doing this to make visibility). Now peek inside the wheel well in the region of the corrugated CV joint boot. You will see the obvious hydraulic hose. If you have ABS, you will also see a skinny black electrical wire. Check carefully! the wire may not follow the same path as the much thicker hydraulic line!
As for traction control, it uses the ABS. If you do not have ABS, you do not have traction control. If you DO have ABS, you might have traction control, and the flashlight trick will help with that.
Good post, one thing though, in most cases the same gauge cluster is used for ABS and NON ABS (as well as other features) so just seeing the icon doesn't mean it should always light up. That's where your other suggestions are right on the money.
