Ustria?
by Pontual
02/06/16 11:48 AM
Georgia bans 71 oils from 29 brands
by Tom NJ
02/06/16 11:27 AM
Trying to send a Blackstone sample
by 15SilvyEcotec
02/06/16 11:10 AM
2005 Trailblazer getting a new engine
by The_Eric
02/06/16 11:02 AM
AAP: 5 qt Castrol Edge, Boss filter, $30 PP $33
by DoubleWasp
02/06/16 10:48 AM
Make own external backup?
by doitmyself
02/06/16 10:33 AM
What should I use for my next oic?
by dan_erickson
02/06/16 10:25 AM
Motul Sport Ester 5w40 vs Gulf Competition 5w40
by Brit33
02/06/16 10:12 AM
M1 0W-20 EP / 15,745 mi oci / 2004 Honda Accord V6
by vinu_neuro
02/06/16 09:58 AM
Recommend me a small 12v battery.
by dlundblad
02/06/16 09:22 AM
Painful To Find M1 5W30 ESP
by Virtus_Probi
02/06/16 08:37 AM
Conventional oil in a 3.6 Penastar ok?
by oilchangeguy
02/06/16 08:27 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
85 registered (A310, 77GrandPrix, Bandito440, bbhero, Abakev, Ball9320, 10 invisible), 1900 Guests and 205 Spiders online.
56834 Members
66 Forums
244311 Topics
Page 1 of 2 1 2 >
#2522649 - 02/02/12 04:58 AM What is piston slap?
Russell Offline
Loc: Lexington, KY
Also what kind of sound does it make? Does it go away as the engine warms up. I have been told my BMW has some piston slap at 210,000 miles and I should not worry about it.
Russell Casey
1995 BMW 525i M50TU 2.5L-6, abt 236K miles. Rebuilt trany.
1998 Ford Explorer Eddie Bauer 154k miles, 4L-SOHC V6. timing chains replaced
#2522667 - 02/02/12 05:30 AM Re: What is piston slap? [Re: Russell]
SteveSRT8 Offline
Loc: Sunny Florida
Typical slap starts when the car is started, then quickly fades. One of our trucks with 400k miles on it has done it since new.
We own a lot of 'slappers', GM V8's, and they have proven to be very reliable for many hundreds of thousands of miles.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2522686 - 02/02/12 06:15 AM Re: What is piston slap? [Re: Russell]
Tegger Offline
Loc: Canada
A knocking noise.
Yes.
That's correct; it's no cause for concern, just annoying.
My understanding is that piston-slap incidents have increased in recent years as engine designs have changed to suit emissions and gas-mileage laws.
2013 Toyota RAV4 - 47,000 miles - Toyota 0W-20, Toyota filter
#2522704 - 02/02/12 07:03 AM Re: What is piston slap? [Re: Tegger]
Turk Offline
Loc: MN
Oh man, my 2000 Sierra 5.3L has Piston Slap so bad.....
I traded it in for a 2003 and during the eval they did I made sure it was quite warmed up.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2522744 - 02/02/12 07:59 AM Re: What is piston slap? [Re: Russell]
Corvette Owner Offline
Loc: Waldorf, Maryland
Here is a great website about GM's piston slap.
GM's Piston Slap
Here is their definition:
Piston slap is nothing new to piston driven internal combustion engines and compressors. It is the secondary (sideways or perpendicular) movement of a piston against the side of a cylinder bore where the primary movement of a piston is intended to be parallel (up and down) to the cylinder bore. All piston driven internal combustion engines and compressors have a certain amount of piston slap.
Excessive piston slap occurs when the clearance between the piston and the cylinder bore is too great. The piston to cylinder bore clearance becomes too great either through wear, mismatched pistons and cylinder bores at manufacturing or, a combination of both. The audible noise associated with excessive piston slap is due to the perpendicular impact of the piston against the wall of the cylinder bore. Audible piston slap is typically loudest when the engine is first started up. The pistons then expand with heat reducing the piston to cylinder bore clearance thus, reducing the perpendicular impact of the piston against the cylinder wall and its resulting noise.
Edited by Corvette Owner (02/02/12 08:01 AM)
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2522798 - 02/02/12 08:53 AM Re: What is piston slap? [Re: Russell]
daman Offline
Loc: Bad Axe, MI
Basically it's your piston(skirts,very bottom edge)rocking back and forth in the bore when the piston is traveling up and down, the piston to bore clearance is too great. Usually once up to operating temp piston swells takes up that loose tolerance and the noise stops.
it's nothing to be overly concerned about.
"Always"....Mobil 1
Current fill: AFE 0w30
#2522810 - 02/02/12 09:10 AM Re: What is piston slap? [Re: Russell]
Smoky14 Offline
Loc: Nowhere NM
Some Honda engines get piston slap when they get hot. The clearance cold is .0008 and the piston shrinks as it warms to provide adequate gap between pistion and cyl wall. Most pistons expand with heat and thus the noise at start up goes away as the engine warms.
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#2522847 - 02/02/12 10:05 AM Re: What is piston slap? [Re: Smoky14]
scurvy Offline
Loc: Chicago IL USA
What magical material is Honda making pistons out of that shrink as they heat up? Ice, quartz, cubic zirconium tungstate?
wink2
Hypereutectic pistons (AA 4032 or similar) still expand as they warm up.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#2522858 - 02/02/12 10:15 AM Re: What is piston slap? [Re: Russell]
Vikas Offline
Loc: NorthEast
But if you have piston slap because your piston to bore clearance is high then that implies your compression is being lost; correct???
Why would that not be a problem???
#2522882 - 02/02/12 10:31 AM Re: What is piston slap? [Re: Vikas]
OVERKILL Offline
Loc: Ontario, Canada
Because it quickly goes away?
The trend for it happening in more recent years appears to be because of the increasing short piston skirts. Compare an old SBC or SBF piston to one from an LSx or Modular and the height difference is HUGE.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2522904 - 02/02/12 10:52 AM Re: What is piston slap? [Re: Russell]
Russell Offline
Loc: Lexington, KY
Thanks for the info. apparently not a real issue. Possibly just a sign of wear?
Edited by Russell (02/02/12 10:53 AM)
Russell Casey
#2522934 - 02/02/12 11:29 AM Re: What is piston slap? [Re: Russell]
SteveSRT8 Offline
Loc: Sunny Florida
It can be a sign of wear. But most of it is coming from piston design and clearances.
Note that just because the engine slaps a bit does not mean any compression is lost. The rings do the sealing and oil control, our vans that slap use no oil and do not smoke... even with 400,000 miles.
#2523229 - 02/02/12 04:25 PM Re: What is piston slap? [Re: Smoky14]
mechtech2 Offline
Loc: Chicago Area
Huh??
No.
#2523238 - 02/02/12 04:34 PM Re: What is piston slap? [Re: Russell]
SteveSRT8 Offline
Loc: Sunny Florida
What? You didn't know that Honda has their own proprietary aluminum alloy that SHRINKS when heated?
In the frozen North these engines can't even be started!
#2523324 - 02/02/12 05:59 PM Re: What is piston slap? [Re: Russell]
artificialist Offline
Loc: Florida
Either that, or the bore expands faster than the piston expands in certain Honda engines.
2010 Lancer Ralliart Sportback
Page 1 of 2 1 2 >
