Its the oddest thing I tell ya. I got some wearever rotors on my Saturn and they were great for about 10k miles then acted like they were warping. So I took them back and the next set did the same thing, only this time they wouldn't accept them back, so I lived with it. After about 10-20k miles of the warping symptoms they smoothed out and have been great for 10s of thousands of miles.
Another one is the GMB water pump. I installed it and after 10k miles the coolant light came on and I investigated and saw the weep hole was wet, so I reperformed the job and after 10k miles on the 2nd pump the light once again came on. I just decided to live with and didn't investigate where the leak was from, but for a while I had to add a pint every 8500 miles. So I thought a $12 gallon of coolant every 100k or so doesnt seem to bad to live with. Well after adding a pint every 8000 or so for a few times, it began getting longer between fill ups.
So I say if your AAP parts seem to go bad, just give them a little while to work out the kinks.
