Originally Posted By: RamFan
Has there been any data showing that synthetic can resist breakdown longer (not forever) when exposed to coolant and/or water when compared to conventional?
Not to my knowledge. All oils, whether synthetic or conventional, will pick up contaminants, water, fuel etc during the course of their use. IMO....the only benefit to using full synthetic would be under ideal conditions. Long highway trips or commutes with no stop and go traffic, balmy weather and not subjected to extremes. But still, in those conditions even a fine conventional oil would be up to the task of providing fine lubrication.
With synthetic oils, the main selling point is long oil change intervals. However, all of the synthetic oils do state to "follow the recommended OCI as outlined by the auto manufacturer". The auto manufacturers do not have a separate schedule for synthetic oil change intervals vs conventional oil intervals. IMO...it is better to use a blend unless the auto manufacturer specifically states that the owner use ONLY synthetic oils. These are usually found with Turbo engines or severe use...like towing. I guess....it's your money....and you can spend it the way you want.
But for me...I like the quality Dino oils on the market today and will add some synthetic for people who are not prompt about OCIs.
