I promised to try to help a friend/coworker with a very irritating issue she's had with her 2002 Volvo S40 (automatic with only 150k km) over the past couple of years. She still likes the car - but even after spending quite a lot of money trying to fix this issue, it still remains. She's essentially at her wits end with it - but hates to part with it, as it works perfectly when it chooses to. All routine maintenance has been done as per Volvo's schedule, and the car looks great.
The problem is that it intermittently won't start. Put the key in, turn the ignition "ON", and everything lights up as normal. Turn it to "START" - and nothing happens. Not even a hint at cranking.
This only seems to occur after the car has had a short trip (typically shopping), and has only been off for 1/2 hour or less. When this happens, waiting another 1/2 hour to 1 hour seems to allow everything to return to normal. It hasn't ever failed first thing in the morning, or after work. Weather seems to have no impact. It can do this winter or summer. It doesn't do it every time either - so it's difficult to predict.
All servicing has been done by a local Volvo dealer - and there's quite a list. Specifically pertaining to this problem:
- Replaced starter - no change.
- Replaced antenna for immobilizer - no change.
- Replaced immobilizer module - no change.
- Bypassed immobilizer module entirely - no change.
- Replaced ignition switch - no change.
- Replaced engine temp sensor (apparently reading higher than usual at ambient) - still no change.
The battery was also changed a couple of years ago and tests fine.
At first, this only happened maybe every couple of months, but it has gradually gotten more frequent. Each time something was changed - she hoped it was fixed - but eventually was disappointed again.
If anybody has any good ideas to look for, it would be greatly appreciated! She's spent SOOO much money on it at this dealer she's reluctant to start over somewhere else - so I thought I'd try asking here first. It doesn't make much sense to me - but I'm not entirely familiar with how the powertrain controls operate and interact in Volvos to be able to properly diagnose. I'm just hoping that somebody on here somewhere has seen this before!
Thanks very much in advance,
John
John
