total lunar eclipse Monday night (Tuesday AM)
I'm still fascinated in the coincidental sizes and orbits of the Earth and moon that they fit each other perfectly, and are on the same plane.
Amazing coincidence.
they're on the same plane because the earth's gravity due to its larger mass captured the moon into an orbit. this same gravity is what locked it into synchronous orbit and causes the moon to rotate such that only one side of it is ever seen by humans on earth, and the infamous "dark side of the moon" has only ever been seen in person by astronauts slingshotting around the backside of it.
I could have sworn Pink Floyd also saw the Dark Side of the Moon!
That eclipse should be well worth watching if you care to view it between 1:30 a.m. and 5 a.m. EST on Tuesday morning.
The similarity in size is temporary. The moon is moving away from
the earth and in so doing, the moon will slow and the lunar month will lengthen. The 'apparent' size of he moon will be smaller as well.
Yes, many amazing coincidences about our planet, the temperature, the existence of abundant free water, an atmosphere rich in oxygen... If you scaled the earth to a 7" (or 200mm) globe, the area where mankind could freely exist would only be .002" (or .06mm) thick. It's like an orb spinning through space, covered with a bio-film. I wonder how many others there out there...
Originally Posted By: NASA
The entire event is visible from North America and western South America. Observers along South America's east coast miss the late stages of the eclipse because they occur after moonset. Likewise much of Europe and Africa experience moonset while the eclipse is in progress. Only northern Scandinavians can catch the entire event from Europe. For observers in eastern Asia the Moon rises in eclipse. None of the eclipse is visible from south and east Africa, the Middle East or South Asia.
You mean that the size of the full moon as seen from Earth during an eclipse is the same size as the sun as seen from Earth -- as if they were cut from the same pattern? I know; it's amazing indeed.
The moon doesn't ride in the same plane above the Earth, though. It swings, I think, about 20 degrees north and south of the equator. Otherwise we'd have an eclipse of the sun every month at the full moon!
Oops, wrote too fast. I meant to say, "The moon doesn't ride in the same plane above the Earth, though. It swings, I think, about 20 degrees north and south of the equator. Otherwise we'd have an eclipse of the moon every month at the full moon!"
I went for a long walk last night and caught most of it. Thin cloud cover, but still visible through it. It was about -20C but calm so I figured it was a good way to view it while getting some fresh air.
