As long as the reservoir doesn't go empty... air shouldn't get into the PS. Once I accidentally drew the reservoir empty but refilling then turning the wheel a few times. Made the PS burp the air out of the return side.
Having changed the PSF every 2 years in my car and the Camry. I just assumed all cars were similar. All you really need to do is disconnect the return line and plug the return reservoir and make sure the reservoir never goes low or empty.
My Corolla and Camry's power steering takes almost 1 qt. That's a lot of turkey basting considering the reservoir doesn't hold that much fluid.
But if you all like turkey basting then good. I merely provided information for people that have easy access PS like the 9th and 5th gen Toyotas or similar design PS reservoirs that are interested in a complete flush.
