Originally Posted By: REDDOG
zoomzoom,
Do you know where the owner lives? The manganese would suggest outside the US. I would suspect the fuel has been much higher at times than what the report would suggest.
Unusual for M1 0W-40 to thicken like that-usually it thins a bit. The TBN would be interesting to see.
Thanks for posting,
REDDOG
He lives in GA. Mercedes uses FSS system to monitor oil life:
FSS determines the remaining time and mileage before the next oil change is due. This information is displayed in the instrument cluster. Press mileage button twice.
Both, V6 and V8, engines are fitted with a digital oil quality sensor on the bottom of the engine's crankcase just above the oil pan and an analog oil level sensor.
The maintenance interval is increased or shortened depending on the operating conditions (cold starts, engine speed, etc.) or when oil has been added. The distance between service requirements for your vehicle may be lengthened beyond the new 10,000 mile minimum service interval without sacrificing the quality or performance you expect.
FSS monitors oil change requirements based on actual needs. FSS calculates the current remaining mileage and remaining operating time up to the next oil change based on the following information:
