Originally Posted By: Carbon
Originally Posted By: SubLGT
Originally Posted By: StormRider
........Patch plug is a good repair but requires re-balancing of the tire as you have to remove it from the rim..........
Why is rebalancing required? They should be able to reinstall the tire at the same position if they mark it and the wheel before dismounting. Sounds like an unnecessary extra charge.
The patch adds a little weight at the spot of the patch. The amount of imbalance is small, and may not be worth adding the 1/8 ounce that it might take to compensate.
What I don't know is if tires remounted to the same angular position might also need rebalancing. Is there possibly some small radial displacement that occurs when you remount the tire? If so, that would potentially be a larger factor than the patch weight.
Another thing I don't know is if it is practical to leave rim-mounted wheel weights in place during the tire dismounting and remounting processes. If a tire shop does it, I feel they will routinely remove any existing rim-mounted weights.
Took my winter tire in for a slow leak repair today, they removed my DIY plug and replaced it with a mushroom patch. They did not remove the single rim weight while removing the tire, but the tire is about 1/2" inch off from its previous position on the wheel. The patch and labor was free, and the alloy wheel is undamaged, so I won't complain. It remains to be seen how this affected the balance.
