Originally Posted By: Jim Allen
Strategies, huh?
Well, number one... don't top off until it needs a full quart. I've found that a car that burns oil will often burn off that first half quart (or so, relative to actual sump capacity) rapidly, then taper off. Be a little more careful with that if your car has a very low sump capacity, but I believe the engine designer wouldn't have established an "add" mark without knowing the engine will be fine at or near that level. There are exceptions. I have used this philosophy successfully many times with many of my old tires engines. . . .
The Buick (@ 67K miles) isn't bad, a hair over a quart in 5K miles. I'll have to try that -- instead of adding a pint now and then, wait until the "low oil" message displays, then pour in a quart. And I may try using a thicker oil, same brand, as the makeup oil.
Strategies, huh?
