I have heard that there is a coolant which requires zero system pressure and is very efficient. Does anyone know the name? Anyone experienced in it's use?
Yeah, would be propylene glycol. Evans Cooling sells it.
Ran my 7.3 Power Stroke without a cap because we had a leak from an accessory heater line. Without the cap, there wasn't really any pressure build up. Didn't overheat, didn't overflow, and I lost minimal fluid as a result. Was a 500 mile drive home.
Evans coolant has an operating pressure in the 4-7 psi range and boils at 0 psi at 375F
excellent product I use it in everything I drive.
it does exactly what is advertised. that is what I have found since I have used it
