Hi All
I have a Toyota Camry 2006 which I purchased few years back from a dealership. I don't know if it had the original coolant, or was it replaced at some point.
It is due for a coolant change, and after looking into it, there are two coolants: The Red coolant (example Zerex Asian Red Coolant), and the pink coolant issued by Toyota (00272-SLLC2).
Since I did not know which coolant was in my car, I took a look, and I still could not tell. See the attached picture.
1- is it red or pink in the pic?
2- assuming it is red, does it hurt to drain and refill with pink? (since I don't intend to do a full flush, the pink can mix with what is remaining in the cooling system)
thank you.
thank you.
