Originally Posted By: measureman
To answer a few questions-mid size means to me no monster suv.My wife will drive this around town-gas mileage not really important-yes there will be some snow. Probably no off roading.
No towing-really just a grocery getter.
Just looking for the model with the best chance of holding up with miles on it.
Did not think about timing belts! Been there and they are expensive. Which ones have chains?
I hate not being able to buy a new one!!!!!!!!!!!!!!!!!!!!!!!!!!!
How about something from the domestics, like a Explorer, Mountaineer, or Aviator? Full body on frame so if you need to tow in the future you're set, and one in the 2006-2008 range around 100k miles will be under $10k. Yes, I'm a bit biased, but the only fault I've found with ours is that I'm 6'2" and the driver's seat is barely big enough for me to be comfortable on a long ride.
Parts are super cheap, the 4.0 V6 and 4.6 V8 are both rock solid, and neither one has a timing belt. The rest of the drivetrain is pretty good, too. Expect 15MPG in town and 19MPG on the highway. They also have a third seat, but it's really only good for children.
My wife is 5'1" LOL. I knew someone that had an '04 Explorer that the trans went bad at 40K and found out they had a reputation for this. Would this be true of the later ones?
Not so much. The 5R55W and 5R55S were sketchy around 2002-2005. These transmissions only came with the 4.0 though. If you get the 4.6, early ones use the 4R70W. No problems there.
If you don't mind going a little older, the 1995-2001 generation of Explorer is more reliable and has fewer quality problems (for example, plastic panel on split liftgate that cracks on '02-'05 models). With the OHV 4.0 and M5OD manual, you could pretty much keep it going indefinitely if it doesn't rust. The 5.0 is also super reliable. Expect fuel economy to be in the teens though in any '95-'01 Explorer.
You said no monster SUVs, but it's worth noting that for reliability above all else, it's hard to beat Expeditions and Tahoes. If you can deal with the fuel economy and size, the 1/2 ton pickup drivetrains in these are very reliable. There are lots of examples of both with over 300K miles on them. Resale isn't very good on them either, so you can pick up a decent one for around $5K. They tend to be much less expensive than their pickup counterparts.
Really though, I think any mainstream SUV you come across will fit the bill for what you describe. None of them had really bad reliability that I am aware of. You mostly run into issues on older luxury models when their features start to break...for example, air suspensions. Avoid anything with an air suspension regardless of brand...that would include a lot of Lincolns and things like the Saab 97X Trailblazer clone.
