Theoretically, semi-gloss is shinier than satin which is shinier than flat but I think it depends on the manufacturer. I bought a supposedly flat spray paint from Napa and it was definitely satin instead of flat. A satin finish will be more delicate than a more hard-wearing semi-gloss finish. Are you doing all wheels or do you have to match an existing finish? Also, consider having to clean the wheels, and a glossier finish is easier in that regard. A thick layer of brake dust patina is another road warrior option. Doesn't matter what finish is under it.I heard somewhere that satin and semi-gloss are not the same. People say that satin is closer to flat.
I guess I could see that, but wouldn't it matter what the steel wheel is? If it was spoked then silver might work ok (am thinking of my prior Tundra and its steel wheels), but anything else I'm thinking black might look better?The color is your choice, but put some thought in it. I've seen too many ugly Altimas, Civics, F150's... where the owner went through the trouble to paint their wheels black and make their vehicle uglier than it was before.
Love those Ralleys.The classic Corvette Rallye Wheel was painted Argent Silver. You see the wheels painted body color. Why people, why?
Some people use engine enamel to paint their wheels; what do you think about that?Rust oleum is a softer paint. Wont last. VHT wheel paint and duplicolor wheel paint is far sturdier. Can touch it in an hour, but 7 days to fully cure. I would Not recommend rust oleum or krylon or any other regular enamel paint for this application.
i mean, why? I think if there is a paint designed towards the unique case of a wheel, I would not use a paint designed for the different use case of an engine. Especially if I’m going to do the prep work. Spray paint is mediocre enough when compared to professional paints, why intentionally increase your chances of failure by choosing the wrong material for the job? I would need special understanding to willingly do differently.Some people use engine enamel to paint their wheels; what do you think about that?
Scrape off the loose paint, lightly sand the whole area to be painted, wipe down with acetone, mask off tire etc., paint away. It will come out good enough and should last. I've done many wheels like that and looks fine for years.- Do you guys think VHT is the better, off the shelf product vs. Dupli Color or others?? Why?
- One of my steel wheels has the OEM silver paint peeling off, leaving black primer underneath. There are traces of rust around the wheel edges. Please outline the prep stages for VHT or any other paint. Primer first?
Thank you.
View attachment 167077View attachment 167078
The reason why I ask is because there was a guy on YouTube that painted some Volkswagen wheels semi-gloss black using Dupli-Color engine enamel. I thought they turned out pretty good, but you be the judge.i mean, why? I think if there is a paint designed towards the unique case of a wheel, I would not use a paint designed for the different use case of an engine. Especially if I’m going to do the prep work. Spray paint is mediocre enough when compared to professional paints, why intentionally increase your chances of failure by choosing the wrong material for the job? I would need special understanding to willingly do differently.
Thank you. These are steel wheels on a 11 year old daily driver and that plays into my decisions. I'm wrestling with doing OCD job vs. good-enuf. I'm not sure if the remaining silver paint is going to also peel off eventually.Scrape off the loose paint, lightly sand the whole area to be painted, wipe down with acetone, mask off tire etc., paint away. It will come out good enough and should last. I've done many wheels like that and looks fine for years.
