What is the best MO&Gear Oil for 2008 Vette LS3
ant
Louisiana
Cost is no object if real improvements in durability, relaibility and longevity can be expected.
Is the LS3 6.2L or 7.0L?
Originally Posted By: sonyman
6.2L
Thanks sonyman!
ant, here's the whole freakin' page from Amsoil:
2008 CHEVROLET CORVETTE 6.2L 8-cyl Engine Code W
LUBRICANTS & FLUIDS
Engine Oil
No recommendations
All Temps......5W-30
Manual Transmission,.....GLS[1]
Synthetic Automatic Transmission Fluid
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Automatic Transmission,6L80E.....AF6
Controlled Slip Differential, Rear .....GL-5*[2][3]
All Temps......75W-90
Severe Gear 75W-90
Fluids
Power Steering Fluid.....PS
Brake Fluid.....HB
Clutch Fluid.....HB
1. Gm recommends part no (USA 88861800) Canada (88861801)
or equivalant for manual transmission, transfer
case applications.
2. CS IDENTIFICATION: tag under cover-ataching bolt. Models
with limited slip use 4 oz & 4.7 oz on 2007-08 XLR, 2006-08
Corvette Ex. Z06, 2006-08 Z06 6.8 ox of GM part
no. 1052358 additive or equivalentwhen fluid is changed.
3. Synthetic oil is required.
CAPACITIES
Engine, with filter..........5.5 quarts[1]
Engine, with filter..........6.0 quarts[2]
Cooling System, Initial Fill..........13.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 6L80E Initial Fill..........6.6 quarts
Manual Transmission, 6-SPD..........7.4 pints[3]
Manual Transmission, 6-SPD..........8.4 pints[3]
Differential, EX Z06 Rear..........3.9 pints
1. w/o Oil Cooler
2. w/oil Cooler
3. Base capacity 3.5L, W/ Z51 4.0L
TORQUES
Oil Drain Plug.....18 ft-lbs
Manual Transmission
Fill Plug.....20 ft-lbs
Drain Plug.....20 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
OTHER TOP QUALITY PRODUCTS
Mothers® Car Care Appearance Products
By-Pass Oil Filters
I'd use M1 in the engine, Amsoil gear oils. GM engineer I've spoken with said M1 has no wear issues at all and they test with it a lot. Amsoil/PP/Redline/Valvoline are just a few other good choices also if you decide you dont want to use M1.
I'm planning (hoping?) on getting a new Camaro when they come out. I'll probably be using Amsoil HDD 5W-30 as I think that's one of the best oils out there for a (mainly) street driven vehicle that calls for a 5W-30.
Originally Posted By: buster
ant, what did you end up using?
I purchased SSO after waiting several months for a recommendation from Amsoil. My next oil change will be with SSO and an EA047 filter.
consider replacing the factory power steering fluid with Royal Purple PSF, since it isn't designed for ATF.
Everywhere else, I'd recommend filling with Amsoil.
