i had a new lifter maul itself after replacing a whole set ....i used the white lubaplate and following was red goo ..so who and what is the best lub for break in -it must stick to the parts for the lapping to happen without gulling out ...thxs
White Lubriplate is not intended for cam lobe/lifter break in. It is for main and rod bearings. Only use cam assembly/break in lube for cam lobe/lifter break in.
