Hello all,
My 2.2L 4cyl 5SFE Toyota is throwing code 71 check engine codes (EGR fault, exhaust gas too cold, EGR malfunction etc.). No other codes.
Previously, it'd thrown the same code, I swapped a vacuum line out for a new one, and it ran for 3 months without throwing the code again. However, now the code is back.
I'm not particularly in the mood to be pulling and cleaning EGR components, and was wondering if the EGR fault is harming the motor, or whether it is mearly a cold-start emmissions issue? If it's the former, I'll have to deal with it immediately; if it's the latter, I'll put it off a bit.
Following the lines (and of course without a book) I am confused whether the EGR deals with metred air - implying a fault could lean out the motor and result in a disaster, or rich it up and foul plugs etc., or something else I've not thought of - or whether it cannot affect fueling etc.
Any explanation and/or advise appreciated.
