Hey guys, I performed a coolant flush today on my 95 1mz-fe camry v6...this is how I started off
1. Drain radiator through drain cock
2. Tighten drain cock and pour dis-stilled water
3. Turn engine on set heater to max and wait till fan turns on
4. Loosen drain cock and keep repeating all above steps until fluid appears clear
Now my problem is, when I turn on the vehicle, the rad fans won't come on? I even let it run for 10 minutes and occasionally holding it at 3k (to warm up the temp quicker)....I just kept on revving and revving but even with my temp gauge reading in the middle, the fans wouldn't turn on?? I know my t-stat is working because I never had a problem over-heating on the freeway...
So whats the deal here? I just called it a day and poured 50/50 super-tech coolant in there while squeezing the upper rad hoses...I poured it in until it over flowed and no more bubbles were coming out
Did I perform this flush correctly?
