this is close to right but not true, you want to be a little bit to moderately below WOT:
Originally Posted By: Eddie
WOT probably equates to best efficiency and you were not lugging.
It would have been better to drop to 5th and run 80% throttle.
The definition of lugging is if your cam and valves can't use more air to make more power even if you open the throttle more. I don't think you were "there."
I'm going to stick this BSFC map in. I can only begin to explain it.
Basically it's a map of engine efficiency for input vs output, your scenario puts you in or near the "red blob" assuming your engine is cammed/ valved/ set up like a Saturn 1.9 16V. This sort of applies for many econo box normally aspirated smog american motors.,
Hey, great info and chart eljefino. You can see this 4-cyl engine peaks in torque around 3000 rpm, and the sweet rpm spot for specific fuel consumption sits below that torque point by a thousand rpm or so, at around 2000 rpm. This darker reddish circular area (call it the "sweet spot") also sits higher to on the vertical axis--but not at the very top most part, meaning that the engine is running at peak efficiencies near wide open throttle (near WOT); it is actually less efficient at WOT (as the fuel has a harder time finding o2, and the computer actually allows for a richer mix of fuel:air where there isn't possibly enough air for all of the fuel).
The wider yellow area is still a very efficient area of operation; the RPM range this area spans is roughly 600 rpm to 3250 rpm. Thus, if you want to drive economically, don't take your rpm a way over the peak torque rate (like, say, over 4000).
The most inefficient (bsfc-wise) area of operation would be when you are near idle-throttle (bottom part areas) and that's when the pumping losses come in (your engine is working as a large vaccuum pump). However, running at, for example, half throttle is not at all very close to that area we want to avoid.
( I actually think the OP did okay, running it where he did. Maybe the only thing he could've done better is laid off the pedal just a bit. I do that sometimes, loose speed up the hill, and drop below 55 (or 50) and put it from 5th to 4th (or even 3rd). )
