Pennzoil Ultra 5w30, 6277 miles 2009 Infiniti G37
KLB
Chicagoland
Here is my latest UOA for my G37. I'm using WIX oil and air filters. The oil was in the car for almost exactly 3 months. I drive about 60% highway, 30% country roads and 10% city.
So much for this being a 4000 mile oil in your vehicle. I'm with Buster, what were the other oils?
Nice FP, TBN is low for a $28 oil but better than some oils we have seen.
What type of use for the vehicle? Time in sump?
Bill
Bill
Bill
And Mr Bill is having a "moment"...
Thanks Johnny for the obvious... (that's what I get for scanning the board trying to "catch" it "all")
Bill
The first two were both Mobil1
Surprise! (and like Buster I have the same thought process when I saw them)
The hits keep coming.
Originally Posted By: buster
LOL I figured they were! 3x higher Fe wear with M1. Stick with PU.
Break in, big whop. I don't see an issue with either oil. Other then the lab error on the phosphorus in the Ultra everything looks good.
Well, as noted the readings on Phosphorous were indeed wrong. Here is the updated UOA with the correct numbers.
30k miles is WAY pass break in....
stick with PU
stick with PU
Look again 19 and 25K,,that's still breaking in to most on here..
and 23 in 6k for PU? mobil bashers would be all over crying about that number if it was M1
You have to keep in mind that with the higher iron numbers on the previous run that a good portion of the iron in this run is still residual leftover. So the next OCI will almost certainly show iron levels much lower than this one.
Oh....so residual leftover!
I just changed my son's G37 Coupe to Penzoil Ultra on it's second oil change, he wanted to run dino oil for an additional 3200 mile oil interval.
Based on these results, I am glad I did it. Will probably leave it in for 7200 miles.
