Originally Posted By: qdeezie
Any idea who makes their Microguard filter?
WIX
I just ran my MR2 filter (because I know the subaru is the same) and it is identical stat-wise
MicroGard - Oil Filter
Part Number: MGL51394
Line: MGD
1 year limited warranty
UPC: 765809470361
Style: Canister
Outside Diameter (In): 2.685 Inch
Thread Size: 3/4-16 Inch
Height (In): 2.977 Inch
Anti-Drainback Valve Included: Yes
Additional Details
Burst Pressure (psi): 400 psi
Bypass Valve Included: Yes
Bypass Valve Pressure (psi): 8 To 11 psi
Flow Rate (gpm): 7 To 9 gpm
Media: Paper
Micron Rating: 21 Micron
Pressure Relief Valve Pressure (psi): 8 To 11 psi
Wix 51394
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=51394
Part Number: 51394
UPC Number: 765809513945
Principle Application: GM (85-09), Daihatsu (88-92), Infiniti (91-96), Kawasaki Mules, Nissan (91-95), Buell (00-11), Toyota (80-15), Scion (04-09), Atlas-Copco, Briggs & Stratton, Caterpillar, Cub Cadet, Generac, John Deere, Kubota, New Holland, Pontiac Vibe (03-10)
Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.977
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 400
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
