Originally Posted By: engineer20
any tips for a stuck oil filter? in the past, the guy said use an oil filter wrench (pliers) if the cap doesn't work. The plastic pennzoil cap I have, broke yesterday, as in it rounded, (the part where you put in the ratchet, plastic got removed from there, so it's > 3/8 drive in reality not because some plastic came off and it didn't spin), so then I tried the oil filter wrench, it didn't work either, punctured the oil filter, and oil dripped out, but it wouldn't work, now, i tried in multiple spots, but it just wouldn't come off, what advice do you have with this? is this car safe to drive? my plan is add in the 4+ quarts of oil, and take it to a nearby quick lube (liek 3-4 miles away) but if the quick lube dosn't work, I can call a tow truck? the tow truck company will tow me to a place about 5 miles away, so within the aaa radius, i can use a aaa service call for free, and if the quick lube can't remove the oil filter, i can go to the tow truck place, as they're a repair faciility and an indy mechanic shop too. So ateempt to drive to the nearby quick lube, or is it unlikely thye'll be able to remove the filter, and just call the towtruck and have their facility work on it since thye're a shop with more equipment? i punctured it and now the filter is "pinched in" at multiple locations, isnt't this unsafe to drive since there wont' be any oil pressure with the filter liek this, or is it ok for a short drive, or will i damage my engine? oil is coming out of the filter, but the filter only has so much and it's dripping/not coming out quickly, so if i fill my engine /pan with the 4+ quarts, and like mechanic, but is it safe to do so with a punctured filter, because the filter provides oil pressure and with a damaged filter, you won't have that oil pressure! any opinions? thanks. so i'll know what to do next, tmrw morning.
Tow it.
How did you puncture a filter? I have been using a filter cap for 20 years and have never been able to puncture it. If a plastic cap doesn't work use a metal one, dealer sells it and many parts store do too.
Filter has instruction on it to tell you how much to turn, usually around 3/4 turn when the gasket first touch the engine. You should never try to grip so hard that you pinch the filter.
i rtv'ed the trans case with black rtv on the outside, shoudld i have used red, since the rtv/stuff i see coming out is red, but it coudl've became red beacuse trans fluid is red
or is black rtv ok? and is black rtv ok to replace the trans pan gasket when i drop the pan, or no? Thanks.
the stab link won't come off in the front because i bent it, the nut will easily move, but i roudded the hex, and the whoel threads is pointed downwards/bent downwards
will an angle grinder be able to chop it off? Thanks. and i see the bottom ball joint of that front left stab link is leaking grease, but not the top one, and the control arm bushing looked similar to that in the picture, not broken or anything but many mini tears beginning.
The job of the RTV is to seal, if you can't see between RTV vs ATF you should just clean it up and see where it is from, or add a florescent dye to the ATF and use a black light to see where it is leaking.
Stop messing with the link if it is bent and rounded, ask the shop to fix your mess for you and pay up, before you get yourself into an accident or damage more parts.
Live and learn.
