Probably significantly less than the cost of one tank of gas on that Tundra.Just curious, how much savings are we talking about here ?
Z
Z
Kirkland 5k oil change intervals will be mor beneficial to your engine than mobil1 every 10k miles
Kirkland may boost oil supply with proposed $259M Bottleneck refinery expansion
Just outside of the Gulf, Texas – Kirkland (non-Advanced) today announced the successful startup of its Wholesale Warehouse-backed refinery expansion project, which adds 250,000 five quart jugs (0w20-5w30) per day of capacity to a few thousand of it's Wholesale stores. Corporate intentions are to wipe Mobil-1 Vanilla off the face of the earth.
I don’t think a generic oil sold in Costco (only) is going to wipe Mobil 1 off the face of ANYTHING! XOM is just a LITTLE bigger…Kirkland may boost oil supply with proposed $259M Bottleneck refinery expansion
You said you "established" 10k with M1. If by established you mean UOAs show that's a good and safe interval, why change? (@tig1)I’ve used 0w-20 Mobil 1 on my wife’s 2016 LE Camry, daughter’s 2011 Camry (both with 4 cylinder) and my 2017 Tundra 5.7l Limited and up till this year using an established 10k mile oil/filter interval. Im 70 yo but still change the oil on these because of the high probability of some random shop mechanic screwing up my cars. A real issue in SE Fla.
Even with my good used oil lab test results, I decided to fall back to a 5k oil interval, on a 3 vehicles.
So, now the consideration. With less demanding intervals, I’m considering going to Kirkland 0w-20 full synthetic.
Is that Kirkland oil good enough for this 5000 mile interval? See any drawbacks on this obvious cost savings change? I’d love to see a Virgin lab test of the Kirkland 0w-20 full synthetic?
You’re right. Even assuming you rounded the figures, say KS regularly for $15 and M1 regularly for $30, it would be a complete wash. No actual saving to be had doing it this way.Cost Drawbacks - M1 is around $5/qt. Got my most recent shipment of KS for around $3.60/qt. So the KS will be slightly more expensive at the shorter interval....but if you stick with M1 @ 10k, it's the less expensive option.
No, I haven't had a reason to do UOAs in the last 45years using M1 oils. UOAS are good for checking the condition of the oil, such as coolant, dirt, or fuel contamination, not much else.You said you "established" 10k with M1. If by established you mean UOAs show that's a good and safe interval, why change? (@tig1)
In S FL I'd be using 5w30 but that's me.
But to answer your Q, KS should be totally fine at the shorter interval - and likely will be fine at an even longer interval as well.
There is no evidence that Mobil1 is better than Kirkland. Its an established brand name with a lot of marketing. Still remains to be seen that you actually getting anything more out of Mobil1 vs Kirkland
Keep in mind those calculations are ESTIMATES and may be off, considerably. Different types of base oils really seem to have a considerable impact on the figures for example.M1 xW-20s are loaded with VIIs and have medicore HTFS (base oil viscosity). Ravenol and Pennzoil do a lot better in these grades.
Automated calculator for the A_Harman index, VII content, and base-oil viscosity
I have now fully automated my A_Harman index, effective VII content, and base-oil viscosity calculator by building in the ASTM D341 viscosity - temperature relation (Walther formula) into the spreadsheet. If you want to calculate these values for an oil, you can either (a) make a copy of the...bobistheoilguy.com
Mobil is at least willing to publish some of their in-house limits for the various sequencesThere is no evidence that Mobil1 is better than Kirkland. Its an established brand name with a lot of marketing. Still remains to be seen that you actually getting anything more out of Mobil1 vs Kirkland
Thats true, btw I was referring to regular Mobil1 (not extended performance). People do get solid results on Kirkland/Supertech, so I am not sure why someone would assume that regular Mobil1 can last 10K miles vs only 5K miles for Kirkland, they are likely very close for the same OCI.Mobil is at least willing to publish some of their in-house limits for the various sequences
Regular M1 is listed there too.Thats true, btw I was referring to regular Mobil1 (not extended performance). People do get solid results on Kirkland/Supertech, so I am not sure why someone would assume that regular Mobil1 can last 10K miles vs only 5K miles for Kirkland, they are likely very close for the same OCI.
About 28% less for list price Kirkland vss on sale $10 off Mobil 1.Just curious, how much savings are we talking about here ?
Z
Yes I did a series of 3 10k miles UOA and the TBN and other life metrics look fine.You said you "established" 10k with M1. If by established you mean UOAs show that's a good and safe interval, why change? (@tig1)
