Originally Posted By: Traction
Interesting explanation. Takes a long time for oxygen to migrate back into the tire. Water vapor can migrate back into the tire also. No scientific explanation, but moisture outside the tries to equalize with the dry air in the tire like a wick.
Nope diffusion IS the scientific explanation...it's been understood for ages.
Yep, will take longer for it to leak in, as I showed with the driving force (pressures).
Interesting if you want to minimise oxygen migration rate THROUGH the rubber, you need to have 3psi inside the tyre to start with...that's 3 out of the 45psi absolute, or 6.7% oxygen in the tyre at initial fill.
