*New Amsoil SSO 0w-30
Wow, very nice! -drools-
A full synthetic (Group IV?) 0W30 that isn't thicker than a 5W30... I'd definitely like to use that someday.
Looks like a nice oil for the winter time
Having said that,I have a question. For my 95' Explorer,in the application guide,it shows XL 5w30, ASL 5w30 and TSO 0w30.
Now,being as this is a 0w30,I'm assuming this would work in the Ford specifications. Some would tell me if I'm wrong
I saw that the other day in the “what's new” area at the Amsoil site. My direct jobber did not know what I was talking about when I mentioned it was updated. Wow a 13.2 TBN, is that the highest of any Amsoil oil?
They mentioned it is a 35th anniversary edition. I think they might be making more of the signature series products.
They will be coming out with two new brake fluids as well.
The specs looked pretty good at a glance on the screen.
They will be allowing you to custom make EA air filters at some point as well. They will have a form that you fill out the dimensions send it in a get your new custom EA air filter.
TYPICAL PHYSICAL PROPERTIES (revised 08/07)
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil (TSO)
Kinematic Viscosity @ 100°C, cSt (ASTM D445)
10.4
Kinematic Viscosity @ 40°C, cSt (ASTM D445)
56.4
Viscosity Index (ASTM D2270)
177
Cold Crank Simulator Apparent Viscosity @ -35°C, cP (ASTM D5293)
5831 (-35)
Pour Point °C (°F) (ASTM D92)
-51 (-60)
Flash Point °C (°F) (ASTM D92)
230 (446)
Fire Point °C (°F) (ASTM D92) 246 (475)
Noack Volatility (ASTM D5800) 250°C for 1 hour, % weight loss 8.5
High Temperature/High Shear Viscosity cP, X°C, X s-1 (ASTM D4683) 3.2
Four-Ball Wear Test (ASTM D4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.36
Total Base Number
>12.1
AMSOIL Signature Series 0W-30 Synthetic Motor Oil (SSO)
10.3
56.56
173
5927
-51 (-60)
230 (446)
Four-Ball Wear Test (ASTM D4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.406
Noack Volatility (ASTM D5800) 250°C for 1 hour, % weight loss 8.65
Total Base Number
13.2
$9.95 per quart! Wowee zowee. I love Amsoil and I love 0-weights, but I'm thinking it's too much.
Can anyone give a truly justified reason for getting this over the ASL?
My thoughts as well,way too over priced. I am considering the ASL though
