Originally Posted By: ARCOgraphite
Do $400,000- supercars have inferior engine design that require a "specialty oil"?
Re-posting this for posterity. I'm sorry but I can't imagine it requires a response.
And if you make this a viscosity requirement, Why is Dr. Haas (sucessfully?)running a thin oil in his supercars -AG
Read his posts. It is because he only drives them for short trips and never races them. But this is a non-sequitur. You're responding to a point that was never made.
no shearing through the oci
When Mobil 1 0w-40 shears, fuel dilution can rarely be ruled out. Can you show that Mobil 1 10w-30 HM would have retained its viscosity under the same circumstances?
Re-posting this question because you dodged it.
one or more of the spec on the 0w-40 bottle prob disallow shearing out of grade. I will assume Mobil is using special shear stable vii in this 0w-40 - AG
Exactly the point.
Only that mobil says it has extra, the sulfated ash % of 1.3 on the datasheet; I do not know the boron % of the HM oil - I'll concede this moderate to high boron dose % FM/EP is special and welcome in the formulation of the 0w-40 - AG
Sulfated ash =/= EP properties.
There is no -40c mrv published for the HM10w but if its 85% pao then it would have a servicable pump at -40 as the spec aloow 60KcP, IIRC - AG
Thought experiments are not the same as evidence.
The BMW LL01 spec, not directly but oil must be long drain serviceable. I dont like excess Ca adds as its traditionally EP/AW competitive. - AG
How do you know this is even a significant hindrance for the 0w-40?
How much Ca does Mobil 1 10w-30 HM have, anyway?
Bench racing is fun and all, but if you're going to make bold assertions you should back them up with data.
if the "exotic" engine cant survive with 3.5 HTHS oil regardless of low shear SAE viscosity in daily sport driving, then the engine is defective. - AG
Wow. You should write letters to Porsche, Lamborghini, Ferrari, BMW, and Mercedes. Tell them about this amazing insight before they ship even more defective engines! Thousands of customers are counting on YOU!
I was trying to show they are more similar than apart
No, you weren't. Your original point was that 10w-30 HM was better.
I will concede too that what is unseen about the oil can make it outperform
Then, I'm sorry, but you have to concede that your entire argument therefore evaporates. Again, exactly the point. You can't look at a PDS, an MSDS, and a $20 VOA and immediately assume you know enough to know how the oil will perform.
Exactly the point.
