Michelin Defender LTX craking
Canuck - moved to —> California —> Texas —> ???
The tires are four years old pretty much on the dot and are cracking already. Never had a tire that would do that this soon. They have never been under inflated or abused in any way. I don’t think I’ve ever even used a tire shine on them.
Nothing too alarming at this point, but pretty disappointing from a premium brand.
You park your vehicle outside? Or garage kept? You do live in the south, so you are going to get more sun.
I quit using Michelin years ago due to a cracking problem. Cracks were pretty deep. Michelin denied warranty. I denied them a repeat customer.
Never owned any Michelin that did not crack - and chip on our gravel roads. We spread our miles across several vehicles - so tires age.
If I had a single vehicle and did 30k/year mostly highway - would run them
every Michelin cracks. they'll still last 6+ years even if they're cracked for the last 4
I have some PS2s on my S4. Been on since maybe 2009, 2010. Other than uneven wear due to alignment issues, no cracking.
How fast should he drive with tires that are obviously starting to weaken?
The outer few mm of rubber is not really providing any structural strength, its just there to protect the belts(on the sidewalls) and provide grip on the tread surface. Once the cracks get deep enough, then they start letting air and water into the belts and then the tire can weaken fast, but the belts are what's holding the tire together.
I don't really worry about tiny cracks on the tread at all as there's lots of rubber, then lots of belts, but its not ideal to have any sidewall cracking, as now you have to monitor their depth.
From what I saw in the pictures though, I'll run those without worry.
Perhaps it is time for me to step in.
The reason we are interested in cracking is that it is an indication of the state of the rubber inside the tire, where it really matters. The cracking itself isn't the problem.
Michelin uses a harder tread compound and a harder lower sidewall compound and those are more prone to cracking. Michelin even publishes a chart showing what level of cracking they think is acceptable and what is not. Here's that chart:
I go into more detail here:
Barry's Tire Tech: Tire Aging and Weather CrackingMichelin Cracking Chart
