Hi all.
Just bought a litre of Mazda lf22 premixed coolant. On the back of the container. They write that you must not mix it with water. Because it will thin it and lower the effektiveness of the coolant.
That get,s me thinking. What if you have lets say a blown headgasket. With oil in the cooling system to follow. That will have to be flushed out with water. And no mater what you do. There will still be water in the cooling system when finally refilling with fl22.
That will also thin it up?
I am curious because I had the cooling system in my Mazda flushed with water and filled up with fl22 a while ago. It,s freezing point is about -33 celcius.
What are your thoughts on this?
Thanks.
Søren
Thanks.
Søren
