BSL- I used 15w40 in my Kohler Command V-twin, Courage V-twin and old girl K-series. Zero effect on the hydraulic lifter system the Commands use.
From what I've experienced, Commands strictly on a conventional 10w30 diet seem to get a little bit smokey and leaky around the 500hr mark. Will 15w40 prevent this? I have no idea. The heavier-duty oil makes me feel better is all.
Kohler recommends 10w30, they don't require it.
40wts are an ideal oil IMO for old K-series and the lesser built Courage engines.
In case you haven't discovered this, Motorcraft FL400 (or color of your choice) oil filters are a great oversized option for Command V-twins.
I've got nothing against 10w30, I just make sure it's an oil designed for small air cooled engines, not an automotive 10w30.
