Originally Posted By: daves87rs
Originally Posted By: NHHEMI
I had a 2011 Patriot 4WD FDII w/ 2.4L and it was a great little vehicle. Excellent MPG, roomy even for my fat butt, and no problems to speak of. Had it for 3 years and took a lot of long road trips/vacations with it. I would buy one again in a heart beat. I sold it in 2014 because I always bought a new car every 2-3 years and the new Cherokee was out and I wanted to try one of those.
Most commonly reported issues with the Patriot are front suspension issues( cheap and easy to fix if you run into that ), sunroof leaks( I had a sunroof and not one drop ever leaked even when going through a high pressure car wash - issue is the drain tubes get kinked during assembly or blocked layer with dirt and debris ), and the CVT( I had a CVT and it was fine ). Those are really the three common things with the vehicle that I read about in my years on the Patriot boards. Most models come with a 6spd AT now though so the CVT is avoided in most cases.
The only other "issue" people would complain about quite often is the MPG with the FDII Off Road option. I guess people didn't bother to look at the MPG rating and see that w/ FDII the MPG really takes a hit. It is a real and substantial hit too and from what I saw the MPG rating was overly optimistic and hard for those owners to reach. You should ONLY get the FDII option if you will do a lot of real off roading. Otherwise stick with the FDI if you get a 4WD.
I loved the MPG of my 4WD FDI Patriot though. Conservative drivers can far exceed the MPG rating in FWD and 4WD FDI with ease. I would get as much as 34 MPG highway on trips and always averaged 30 MPG+ for the entire trip. Normal mixed driving netted me low 20's. Another area I felt the Patriot excelled in was bad weather. That thing was a little tank in the snow. It would go through anything I asked it to.
It did everything I wanted it to do and then some. I was very happy with what I got vs. what I paid. Only thing it really struggled with was towing my boat. Even though my boat @ 1700lbs was under the 2000lbs max towing capacity of the vehicle( with tow group which is a MUST )it was about as much as the vehicle could really handle. 2000lbs is not some underrated government agency mandated "safety limit" purposely set low to protect us from our selves. It is a real world max weight the vehicle can handle. If you are going to tow make sure the weight of the towed item( include trailer and all stuff in it )does not exceed 2000lbs!! 1500-1700 is better.
Hope this rambling helps. Haven't had one for a few years and I remembered things as I was typing.
It helps bunches!
Thank you for the info....
daves87rs;
just noticed that I said I had an FDI and FDII in my initial post to you. Sorry about the typo. I had the FDI. Just so it is clear.
It helps bunches!
daves87rs;
