Originally Posted By: dgunay
I broke few Pennzoil sealed caps when i was at Walmart, because i thought there must be a foil seal under the cap, and tried to find a Pennzoil jug with it.
Finally realized that there is no foil seal in the Pennzoil jug(thanks BITOG!!), and bought one that still has the sealed cap.
But i can't really comment about different oil levels in the jug.
Why would you do that?
Because that was a mistake. It was the first time ever purchased Pennzoil. I just wanted to check the foil seal before buying it. I didn't do anything to the oil.
I chose the sealed one because i will keep it until the next fill.
By opening the other jugs, you make them unsellable.
And then you choose to buy one that was sealed because you prefer the factory sealed product.
So I guess you feel you are the only person in the world that matters?
Now are you going to refill the jug with your old oil and return it with your receipt?
Maybe you can use the refund to buy some ethics while you are at Walmart.
It's on aisle 5 between honesty and integrity.
