And you didn't have to put up with us BITOG guys.This guy had the whole thing done in 25 minutes. All I did was listen to tips and pointers and and hold a flashlight. $40 well spent.
My gas mileage has since improved and I have no more hard starts or rpm jumps on start up.generally, if you have a CEL with no drivability problems, you can drive that sucker for the rest of the vehicle's life with no ill effects.
I could be wrong but I don't know how the part you replaced would affect either of those.and I have no more hard starts or rpm jumps on start up.
A malfunctioning purge valve can cause many a drivability complaintI could be wrong but I don't know how the part you replaced would affect either of those.
You can, but should you?generally, if you have a CEL with no drivability problems, you can drive that sucker for the rest of the vehicle's life with no ill effects.
I never much cared for the kicking the can down the road mentality
But then I've got an emissions inspection to pass every year, so I'm forced to keep up with my vehicle
A check engine light on CAN mean
The days of the MIL being an emissions only tattle are long gone, and the longer you put it off, the more difficult it's gonna be IMO
- No remote start (GM)
- No VSC/Traction Control (Toyota)
- An annoying chime (Ford)
- No cruise control (Toyota/Subaru)
- Lack of pending codes/drive cycle monitors, so future problems will be harder to diagnose
- Do you wanna buy a used car with the light on?
