And tends to bring out those who live under the bridge.They’re currently good filters. Careful, though, this kind of question angers the museum curators.
Insensitiveunder the bridge.
I hope they weren’t living under that Baltimore bridge.And tends to bring out those who live under the bridge.
I figured most of the latest Purolator One's have a white synthetic media these days & the Bosch Premium has more of a blend (Yellow/Tannish) color? Maybe the Bosch has changed since I've looked at them last. Are you sure there's no difference between them?I've been using P1 clone US made Bosch Premium 3323 for a while now on Honda and Nissan. PL14610 equivalent. That's the slightly longer version of the shorty 14612 shown. All have looked great in post use c&ps here. Based my experience, I think it's a good choice.
Good point KC.The PureOne has Puro's highest efficiency in most sizes, and is a good mid priced option. Tearing media was an issue that appears to have largely been rectified BUT check to make sure the louvers in the center tube are sufficiently open before purchasing. JMO.
When has a PureOne ever had white synthetic media?I figured most of the latest Purolator One's have a white synthetic media these days & the Bosch Premium has more of a blend (Yellow/Tannish) color? Maybe the Bosch has changed since I've looked at them last. Are you sure there's no difference between them?
Both use a blended media, and have the same efficiency "rating". While I haven't used the PL14610 recently, past experience, viewing recent c&ps here and youtube and made same Puro plant I'm pretty confident in using the term clone. The one difference, P1 uses PTFE coated sealing gasket, the BP nitrile..... Are you sure there's no difference between them?
As far as I know they use a mix but they've used MORE synthetic media, that is white in color, on the latest One's.When has a PureOne ever had white synthetic media?
Have you seen the latest Purolator One's with white media?When has a PureOne ever had white synthetic media?
Understood Thanks, so to sum it up the previous Bosch Premiums were a clone of PL14610 but since Bosch moved to making the latest Premiums in Mexico there's no longer a relationship between them.Both use a blended media, and have the same efficiency "rating". While I haven't used the PL14610 recently, past experience, viewing recent c&ps here and youtube and made same Puro plant I'm pretty confident in using the term clone. The one difference, P1 uses PTFE coated sealing gasket, the BP nitrile.
But, now that BP production moved to Mexico, no comparison to previous US made BP quality.
