Originally Posted By: Wilhelm_D
Originally Posted By: possum328
So far 2 out of the 3 Puros I have used and cut open showed tear failures. Lemming effect???
The fact that you've decided to cut them open at all is taking place because you're involved in BITOG. I don't know what "tear failure" means. Any cellulose filter media from time to time gets pinholes or small "tears". Whether that's a "failure" depends on whether the filtration was seriously compromised.
Originally Posted By: ZeeOSix
But a couple people in this discussion thinks the media tearing issue is just a fluke and not a big deal because by some miracle of astronomical odds, only the bad Purolators are bought by members of BITOG and all the good filters that don't tear are bought by non-members.
Apparently the concepts of random sample, universe, sample defects, and the like are not to your liking. There are no "astronomical odds", in fact there are no odds at all.
There are thousands of BITOG subscribers, some portion of which are using Purolator filters, or one of the several brands made by Purolator such as Motorcraft, Bosch, Mann, and so on.
I don't see Ford, who sources their Motorcraft filters from Purolator, sending out service bulletins on filter media failures to their dealers.
I personally do not make decisions without sufficient information, and I certainly do not project massive problems based on a few reports.
In your analysis of this issue, keep in mind that all the other brands that Purolator manufactures could have different media used and manufacturing processes used, which could be the reason you don't see media failures in those "made by Purolator" filters.
From what it looks like so far, only certain Purolator brand filters have this media tearing issue. Specifically, the models with the metal crimped seam.
So take only those model of filters and apply your "failure statistics". I've seen this type of thing unfold on other failure issues with vehicles/products and it always starts out low and slow, and as time goes on the failure rate initially based on "a small sample group of data" (like here) does indeed show it was a larger problem going on than originally thought. IMO, that's what this media tearing issue is unfolding to be also based on the data seen here on BITOG.
