B BAD1 Joined Aug 2, 2008 Messages 71 Location Canada Apr 5, 2009 #41 Originally Posted By: BAD1 Originally Posted By: BAD1 I am trying to find out if the same valve will fit in the automatic sump pan??? "BUMP" On a Suzuki SX4 2007
B BAD1 Joined Aug 2, 2008 Messages 71 Location Canada Apr 5, 2009 #42 Originally Posted By: tropic You can buy them online if you want: QwikValve. Not sure if it's the site I bought mine from, but the part numbers are the same. The one for the Honda also needed the adapter because the drain on the oil pan is recessed. edit: here's the site I used: QuickOilDrainValve.com Another place I found also http://lubricationspecialist.com/front/showcontent.aspx?fileid=105
B BAD1 Joined Aug 2, 2008 Messages 71 Location Canada Apr 5, 2009 #43 Originally Posted By: hate2work Also, for anyone worrying about the lever getting bumped open, there is an optional clip you can get that secures it very well. Yes go to this site scroll down to the bottom and you will see the clip It is a 5/8in clip Last edited: Apr 5, 2009
M Mr Nice Joined Sep 12, 2004 Messages 24,362 Location Central Florida Apr 9, 2009 #44 No need for that clip, the lever stays put.
