Originally Posted By: artbuc
Originally Posted By: Trav
Trav, does this video convince you? Do you use a vacuum extractor for motor oil and ATF?
On most Euro engines I use one as the dipstick tubes are usually larger diameter and go straight in, they were designed with this type of tool in mind. US engines no so much, many have small diameter tubes and have all sorts of twisted and kinks, many you cant even get the tube in very far.
For most transmission no, I just use a big pan and drop the back down first on the ones with no pan yes I use it. For someone doing just drain and fills every few oil changes to keep the fluid fresh then sure not a bad thing.
