Equipment longevity (engines, trannies, gear boxes, sewing machines, firearms, etc) is not a function of what lube is used. It is a function of the overall maintenance program.
If you used dino oil too long, such that the ability of the fluid to adequately perform its function is compromised, the result will be undesirably altered equipment lifecycle. If you use synthetics too long, such that the ability of the fluid to adequately perform its function is compromised, the result will be undesirably altered equipment lifecycle. If you use either a dino or syn, within the limits of each fluid's capability, then the lifecycle of the equipment will not be adversly effected.
This is, withou any doubt in my mind, where 99.99999999% of folks (including most BITOGers) fail to understand the nature of the topic.
Equipment longevity is a function of the overall maintenace program. Fluid selection is but one of many critera to be considered; others includ severity of use, ease of product attainment, cost of products, capability of products, unique equipment considerations (prone to failure? in what way?), etc, etc.
The proper way to maintain any piece of equipment is to set in mind a level of desired performance, and then manage the maintenance of the overall program to sustain that level. In the case of fluids and filters, we look to condemnation limits in UOAs, particle counts, physical obervations, etc.
If you said to me that your engine died because dino oil allowed it to sludge up or grind to a halt, I'd have to say you're an idiot. It is not the fault of the lube; it is your fault for not adequately managing the maintenance program. Period. No fluid changes itself. If your equipment fails, it's because you didn't match your action plan to your products used.
Premium products (in this case, fluids and even filters) should be judged based upon what level of service they can maintain, relative to the duration of time they can provide that service. This is about ROI of the product and nothing more.
Read my signature line. Then re-read it. Then read it yet again. Read it until you "get it" ...
