quote:
Originally posted by ediamiam:
Let the car cool down for about 1/2 hour. Loosen the filter first enough such that air can start draining into an empty pan, then drop the filter. Puncture the filter to allow draining. Allow it to drain into a gallon container. Drain the oil pan. While oil is draining, prefill a new oil filter and install it. Inspect engine for stuff, belts, check clamps, fluid levels, signs of new leaks, battery water... Replace pan plug. Add oil. Startup and check plug and filter for leaks.
