Over the years I have thought about this and am increasingly of the opinion that this is more urban legend than anything else. I just started thinking about all those square inches provided in a good Wix/ChampLabs/Purolator (my favorites) or whatever filter and the amount of particulate matter that would render the media essentially blocked to force oil around the bypass.
Obviously I change my filter at every oil change - afterall it's cheap insurance, required by the manufacturer, has old oil in it, etc etc etc. I'm certainly NOT advocating skipping the change but by the same token I'm not convinced that if you A) an engine is shedding chunks of metal in sufficient quantity to block the paper and B) that I should lay awake at night worrying about going a tick over the drain interval as I may be sacriligiously circulating unfiltered oil or something.
I figure if enough junk is in there during a normal drain interval to actually plug a filter - you've probably got more serious root cause problems anyway.
What do others think?
