Quote:
There has been endless discussion on this very topic. There were several informal oil filter flow studies done by members in the past. Yes, some filters and media show a little more resistance to flow than others. There are some aftermarket filters and media that either flow or filter better than OEM. The one that I believe is designed to do both well is the EaO series from Amsoil. This filter is made for them by Wix and incorporates some upgraded features like the synthetic nanofiber technology from the Donaldson Synteq line. The drawback for some people is the higher price, like $14 and up. I would think that these filters are better suited to folks who want to extend their OCI's, using a high quality synthetic oil.
Filter media surface area can be misleading, and does not give an accurate idea of which will flow or filter better in use. This is due to the inability to visually determine the quality of the media by just looking at it. The synthetic blended medias usually flow and filter better than straight cellulose media. And the full synthetic medias, like in the Donaldson and Amsoil are even better at both flow and filtration, especially at maintaining that flow and filtration throughout the OCI.
Best to use the recommended filter for your engine and get some input from others with the same engine. Then while a particular filter is on your engine, listen to it carefully when started cold for noise. Some filters will actually allow your engine to run quieter with a cold engine. These probably flow better.
Lastly, try a search here on the oil filter forum and see what you get. There's been lots of good discussion. Use oil analysis if you like. Get Terry's input for your ride.
